What parts help DW the best?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 4, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I just ordered Borgeson steering shaft, AGR box and pump, Pro Comp pitman arm and drag link, and the bolt-in box brace from ORD. I want to do this right the first time, aside from going to crossover steering, what is the best you can do to correct bumpsteer? I thought that it was my tires causing the DW, 38.5x16x16.5 TSL Swampers, but me and a friend swapped tires and now I've got 32" BFGoodrich mud terrains, and it still wobbles like crazy. You think any of the items I ordered will help?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Have you checked your toe-in?
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    If you've replaced all that stuf and still have a wobble, I wonder about your ball joints.
    FWIW, my truck had some nasty habits. I installed the ORD steering box brace and it improved dramatically. I have since replaced tie rod and drag link with new ones and it is tighter still. But the ORD brace did 90% of it.
    -- Mike
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    If you haven't installed any of those items yet, YES all those things will help cure DW. Have you replaced the stabilizer yet? Thats probably one of the most important things to do...
    If you have 38's, I'm also guessing you have a lift and bigger axles... if so, have you replaced the balljoints if its a 44?
    I noticed that the POSITIONING of the stabilizer made a HUGE difference. I have the trailmaster coil over stab. PN 57201. When I rotate it down (under) the tierod, the DW is undriveable. I moved it upwards (over) the tierod, and the DW virtually dissappeared. Movement left to right also had a huge impact...
    Read this for more info:
    http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=365499&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1
    Just my .02
    -Dan
  5. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    I second the checking the toe. Also have you changed your caster? Like adding shims to correct your pinion angle? Looks like too much or too little caster can effect shimmy.
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Send the AGR back and get hydro assist. that will guarentee that you wont have DW
  7. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    I think I'm gonna go ahead and get ball joints too. I'm gonna order from LMC unless someone knows of a place that sells better ball joints or has the same ones at a better price? I got a new Rancho stabilizer as well so I hope I can make it a little bit better on the street. Should I get a Rock Rod tie rod while I'm at it? Or does the beefiness of a Rock Rod increase DW?
