what parts would be needed when going from a 77 203/th350 to a 208 ?
Discussion in 'The Garage' started by R77K10, Apr 29, 2006.
  1. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    if i were to want to swap the factory 77 th350/203 to a th350/208 what all parts would i need
    208 crossmember ? flat one or W- one ?
    adapter ?
    driveshafts ?
    what is everything that i would need to find/swap/change ?
    would i have to modify the shifter cut-out in the floor ?
    anyone know of a 208 truck being parted in central IL ?
    i have to swap the th350 for another or have it rebuilt anyways so i figured that would be the time
    i dont like 203 cases at all
    thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you need a longer output shaft to run the 208, or you can get a short 2wd shaft and cut a little bit off and it will work also
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    X2
    also with that, you need the rare th350/np208 adapter, OR the 700r4/np208 adapter with a 1.75" spacer.
    the adapter dictaces what crossmember you need. tall adapter, flat crossmember. short adapter, W or S shaped crossmember.
