what performance ignition?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Oct 15, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    im getting ready to upgrade my ignition my SB. Should i go with an external coil and ignition box? or should i stick with in cap coil and module? MSD? Jacobs? MAllory? WHat is the benefit of an MSD billet Distributor? I need ideas.
  2. dyeager535
    26,980
    A friend of mine is happy with an MSD Blaster (?) coil. Nothing wrong with stock HEI for almost all applications, except normal wear and tear with about 25 years of use : )
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I have the ACCEL Super HEI, and I'm happier than a queer in a pecker patch!
    John
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    HEI is real good for a mild engine, as long as everything is in good shape. MSD and Mallory are both good. I have had bad results with accel ignition parts.
    There are two advantages to an external box:
    -Muliple spark
    -Rev limiter
    I would make sure that whatever you do, you can use regular stock stuff as spares.
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I really like the MSD stuff, I have a pro-billet distributor and a 6AL box on my 2wd truck and it does great. I haven't upgraded my 4wd yet, but I will use MSD on it as well when the time comes.
  6. meatloafK5
    meatloafK5 Registered Member
    Oct 8, 2001
    53
    Lancaster PA
    I went almost the cheap route and use the Summit HEI with the 48000 volt coil, and Taylor 409 wires(the most expensive part of my ignition) and Autolite platinum plugs.
    It has worked just fine so far. I am considering upgrading to MSD billet distributor and a 6 box.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
