What Pinion Shims for 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Jan 12, 2001.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    What Pinion Shims for 4\" lift
    I would like to know what degree of pinion shims you guys are using with a 4" lift in the rear not the front? Thanks for the help.
    Donovan
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Re: What Pinion Shims for 4\" lift
    I have a 4" lift, 14 bolt FF in the rear (duh), and I am using a 4 degree shim. I have no vibes whatsoever and I've had the truck past 90 MPH. I do have one of the longest possible driveshafts for these truck though, I have the NP 205/SM465 combo. My U-joints also seem to last pretty long.
    Rene
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Hey tRusty...nice BEAVER!!!! LOL!!!!
    "I'm not stuck...I'm just exploring the depth and texture of this mudhole for a while"
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I have a Skyjacker 4" lift on my 90 jimmy 10 bolt np241, and my pinion leaf spring shim is a 4 degree. I also had to add and extra washer along with the t-case drop spacers, it gave me an extra correction degree, and gave me 8 degrees at both ends. I am assuming your asking this because your having vibes from a new lift?
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    hey guys i'd use the brass shims not the alum. they break -
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Are the brass shims readily available? Is this a part you carry and if so how much do they run usually?
    Rene
  7. Donovan
    524
    Arvada, CO
    No I am not having problems yet but I wanted to install them when I do everything. Just wanted to save some time. Thanks for your help.
    Donovan
  8. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    hey rusty, how much longer is your driveshafts?
    Knife.
    knife.coloradok5.com
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I could measure it if you want. The rear driveshaft and the front came with the complete 3/4 ton drivetrain I bought 3 years ago. Someone else must have had the driveshaft altered.
    I do know the SM465/NP 205 combo is the shortest out there for us, which means the longest rear driveshaft.
    Rene
