What pitman arm for crossover?
Discussion in 'The Garage' started by 5trucks, Jan 31, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    Doing the hydro assist/crossover thing and i need to know what pitman arm to get for the 2wd steering box. rig is a 77 k5. Thanks.
    Perry
  2. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    i believe it's a 78-79 ford pitman arm, but i may be wrong
  3. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    If it matters i have a 4" lift.
  4. RGV72BLAZER
    Jan 23, 2006
    2,425
    well i'm utilizing the above mentioned pitman arm with hi-steer, d60, & 52s...so i could be totally wrong
  5. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Thanks for the info. Much appreciated.
  6. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Dont tell anyone but mine came off a heep ZJ. :rolleyes:
  7. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    superlift #1104 , its a ford arm, someone correct me if I'm wrong.
  8. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    No correction needed:waytogo:
  9. chevysmithz71
    chevysmithz71 1/2 ton status
    May 26, 2005
    1,464
    Kingsburg, Ca
    Is that arm Flat or does it have a drop? Using the 52's.
  10. Stomper
    May 11, 2002
    3,767
    Iowa
    It's a drop arm.
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You will need to ream out the taper on the Ford arm to fit the tie rod end most poeple are using. I run the Ford arm too.
