what places do electrical work?
Discussion in 'The Garage' started by bryguy00b, Mar 17, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i was just wondering if i couldnt fix my turn signals and radio and horn from not working..is there a place i could take my truck to have that sort of work done on it? i checked the fuses..they are good..so im not sure whats next..and i dont know anything about electrical stuff..so is there a place that does electrical work?
  2. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
  3. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    I am not asking too be a jerk but do you know how to read a meter? What I mean is if you had someone on the phone to help walk you through it could you read off voltage and resistance? The horn at least should be an easy fix. Is the radio factory or aftermarket?
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea i know but i have no clue what to test...the radio is a aftermarket..its a sony cd reciever.
  5. evilandangry
    Dec 29, 2002
    105
    Norwood, NJ
    The radio and the horn share a ciruit. try disconnecting the radio and see if the horn works. Also check the body ground. It could be loose. It is the small line that runs from the neg treminal of the battery to the front clip.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thanx ill give that a try...
