What pressures to use on torch??
Discussion in 'The Garage' started by Masher, Nov 22, 2002.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I just got a set of regulators and tanks!! What should the pressures for the Oxygen and Acetylene be set at?? Is there a chart somewhere??
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Easy. For cutting, 40 psi oxy, 7 psi acetelyne.
    John
  3. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    Set the torch by sound with a nutral flame(you do know what a nutral flame is right?) and very how hot it is by how it sounds. There is a reason most acetelene gauges go into the red after 15 outlet pressure. DONT GO OVER THAT!!!! You should try to get a book on welding with an Oxy set up.
    Philip
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Hopefully you know how to use them. If not DON'T USE THEM!!!!! You can get seriously hurt with improper use. Depends on what brand your useing to what the pressure should be. Look up the company and give them a call. If it's Victor, they have a very handy chart that i keep handy.
  5. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
