What psi should i dd with???
Discussion in 'The Garage' started by George_Pimpdaddy, Jan 24, 2007.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    Hey just got my 89 blazer back on the road again with the new tranny, tbi 355, and new hedders and duals. Anyways i have no lift and no front swaybar and live in a city with bumpy roads lol. I have 31" BFG Mud terrains on the rear with my posi and 31" bfg all terrains on the front, both sets are 90% tread left. my question is what would a good pressure be front to back? thnks for any help as i want my tires to last as long as possible. :haha:
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    whatevers on the side of the tire
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the pressure on the side isn't always the best to run, it is the maximum, imo, the best way to set pressure is to put some in, roll it forward through some dirt or a wet spot on the driveway and see if the whole tread is dusty/wet, if it is in the center, drop pressure a bit, if it is outside, raise a bit and repeat, i am running about 18 psi in the rear tires on my truck to keep them flat on the road.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    32 to 35. Safer to run with a slightly over inflated tire than an under inflated one.
  5. 81K5GUY
    81K5GUY 1/2 ton status
    Jan 30, 2006
    943
    Rockingham ,N.C.
    I run 33's and have around 25lbs in em on my dd ,seems to help the ride alot.
  6. George_Pimpdaddy
    Oct 17, 2002
    1,306
  7. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    When I was running BFG AT's 31x10.5 I followed what was on the door sticker. 30psi-front 35psi-rear. Worked well for me.
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    When I ran 33x12.50/15s I ran 35 all the way around. Between that and frequent rotation/balance they lasted forever. They were BFG MTs. The front tires just barely cupped after a lot of miles. I see a lot of 4x4s with the front tires cupping bad.
  9. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I'd run them at about 28-30 for the street. 15-20 for off road.
  10. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks for all the replies guys :bow:
