What Radiator do I need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, Jun 20, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    I call the parts store and they respond with twenty questions due to the different options.
    What is the easiest way to figure what radiator I have so I can shop around and find the best deal.
    They asked if it was a 17" core or 19" core, is this the height of the radiator? If so mine is 19".
    What is the difference between 3 Row and 4 Row?
    Etc. etc. etc.
    Gone Large and Loving It.
    Keith
  2. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    4 row is extra cooling. Once other catalog i checked listed the 4 core for the 454, so... i'm thinking it'd help a 350 run a bit cooler!
    Check www.radiator.com I think they were $165 last i checked.. + shipping
  3. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    For many of theolder chevy's the radiators came in two widths. The bracket on the left side of the truck could be moved to either of two pre-drilled positioins so you could use either size. Check yours to see if it is that way. 4 core radiators have 4 rows of tubes rather than 3. Some GM radiators had only 2 rows. I have a 4 core wide version on the 400sm and a 3 core narrow on the the 350. In the 1980's the heavy duty radiators were all metal, and the light duty had plastic tanks. I'm prejudice toward the metal headers, but my 350 is plastic and so far is holding up OK. I'll buy all metal if given a choice, but I don't really know if it is better.
  4. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Yeah, the all metal is better. Over time the ones with the plastic tank start to seep/leak at the seal when it gets cold due to the different expansion/contraction rates. The all metal expand and contract at the same rate.
    90 GMC Jimmy, 350 TBI, 700R4, 32's
    84 Bronco II 204,000 miles and counting...........that's 206,000 and counting now
  5. MUD_SPEC
    MUD_SPEC Registered Member
    Apr 10, 2001
    49
    I just picked up my 4-row from a radiator shop for $185 out the door, they can be more knowledgable about what can retrofit into your rig than Pep Girls or the Zone. I got the radiator for the same year 1 ton gas Suburban. I had to get new, longer hold-downs and top and bottom rubbers from GM for about $20.
  6. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Here are the part number and Qty. I got these from Russ-> (1) 14018600 Panel Assembly and (4) 6264100 Pads.
    He said they fit perfect
    I am about to do the 4 row too. Good luck
