What rear axle do i have
Discussion in 'The Garage' started by 84CUCV, Dec 29, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    heres a pic thanks
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Corporate 12 bolt, found in GM trucks up to '82 in which they switched to 10 bolts in '83.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Dont know much about the 12b any better then a 10b?
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    barely
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    They're better, by far. Currie builds them. Yep, Currie doesn't do just 9" Ford rears but also 12B rears.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK what makes them better? Bigger ring gear or???
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Same size and spline shafts as a Dana 60 only they are C clip semi floaters instead of Danas full float. Ring gear is also larger than the 10 bolt.
  8. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Not much bigger in diameter . 10 bolt =8.5" 12 bolt = 8.875" .
    Old school 10 bolts had 27/28 splines side gears while 12 bolts had 30 spline. Basically the 8.5" 10 bolts are a slimmed down version of the 12 Bolt and most folks agree that GM went too far. 10 bolts are not known for strength and 12 bolts are usually considered the basic minimum as a starting point with small tires.
    HTH's Tom
  9. dhcomp
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Guess i was wrong :doah:
  10. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Not really , ha,ha...
    It appears that GM wanted to offer the bare minimum that would get the job done and it seems like they found it in the 10 bolt 8.5".
    Tom
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    cool thx guys good to know.
  12. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    12 bolts aren't any stronger than a 30sp 10b. In fact, the 10b has a stronger pinion shaft, and the R&P in general are easily as strong as a 12b. Anyone who replaces a 30sp 10b with a 12b as an "upgrade" is doing nothing but wasting their money.
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK i see thanks
  14. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    hmmph., cost me 150 bucks to trash my 10blt and go to a 12bolt when i broke the carrier and never had a lick of trouble from that 12b, they are, if only nominally, stronger...
  15. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Well, the stock carrier is the major weak point in the 10b. Aftermarket carriers generally hold up nicely, though...
    Then again, I am one who pulled a perfectly good 10b from my ride and replaced it with a 14bsf, just in case :wink1:
  16. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    By looking at the numbers, yeah it's not much bigger but I put one in my 74 stepside 2WD with a 580 HP 468 and 11" slicks. Yes when I pulled it there were obvious signs of wear. However I'll kiss your a$$ on the 50 yard line on super bowl sunday if you can find a stock 10 bolt that will do that for two years.:D
