What rear end in an '02 Duramax?
Discussion in 'The Garage' started by pismorat, Sep 23, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I am looking to change the differential fluid in my dads truck, but need to know what rear end is in it to get a gasket. I don't want to go to the dealer, and my dad doesn't like using just rtv. Any thoughts - 14bff???
  2. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    if the cover kind of looks like 14ff cover its the new 11.5 corp axle. if just exactly like 14ff then old std 14ff. most likly 11.5 new axle.
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    11.5" Full Floater 14 Bolt....
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I thought they were a AAM axle??
    You can buy a sheet of gasket paper and cut one out. Clean your dif cover, mark the out side edge and the holes, then cut out the outline. Next, cut a hole in the middle where the ring gear can come through. Place it over the lip of the dif housing where the gasket will go. Take a round piece of metal and score the inside edge against the inner lip of the housing. Cut the scored mark out, use a hole punch for the bolt holes, and whala, you have a gasket.
    Before you install it, make a template so you don't have to go through all this again. :D
    Or you can just buy one :o
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    It is made by AAM
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Do it right
    11.50 ring gear. Go to the dealer get the part and be done with it. It takes synthetic gear lube too you know...
