What Recovery gear Should i get
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pplblazerdude, Feb 9, 2003.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I am wonting to get some recovery gear for when i start wheeling and i am not going to get a winch because i cant afford one seeing that im 15 and not able to work except during the summer. But what all should i get. What all do u guys have besides winches. Id appreciate all the help i can get.
    Clint /forums/images/graemlins/k5.gif
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Buy a good towstrap and bring buddy (preferably one with a winch /forums/images/graemlins/smile.gif).
    And those things called 'come-along' or 'power-pull'..... Hand ratcheting devices.
    We actually hand carried a block-and-tackle up to a bad stuck once. It was an 8 way so for every 8 feet of movement in the block and tackle the vehicle moved 1 foot..... Lots of power tho.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  4. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    id say have 2 tow straps, a high lift, a hitch in the rear with a pin, and 2 tow hooks up front, at least
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    in order of importance...
    1) other off-roaders
    2) recovery points (hooks, d-rings, clevis mounts, whatever)
    2) snatch strap
    3) shovel
    4) winch
    5) one of them pully shackle things that lets you do a double line pull
    6) tree strap
    i assume you are a friend has a cell phone...
    j
  6. agrezy1
    agrezy1 Registered Member
    Dec 14, 2002
    49
    yucca valley,ca
    1.hi lift jack a must i dont wheel with out one.
    2.couple of good snatch straps.
    3.a decent size shovel i used to use a little gi style but they suck now i got a regular size shovel.
    4.a cell phone even if its not activated it should be able to call 911 you might have to hike to get a signal but better to hike for a signal then hike home.
    5.let someone no where your going and when you will be back.
    6.i carry a sheet in my glove box with all my vital information med. history,emergency numbers for someone to claim my carcuss if things go bad.
    7. wheel with some buds, no i dont mean the green kind!
    good luck and have some fun /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  7. Grim-Reaper
    7,385
    Atlanta
    This is the club I wheel with mandatory equipment list. One thing I would like to point out is chain is not something to use for jerking a truck out. It's a good way to get somebody killed. Chain is good for rigging up a hand winch or a Hi Lift but a propper "RECOVERY" strap is better and stronger for getting a vehicl unstuck using a second vehicle because it acts like a big rubber band.
    A recovery strap will streach and should not be confused with a tow strap/ Tow straps do not streach so be careful to make sure of what your getting. Personnaly I like Keeper brand. I have been using the same 2x30 strap for 6 years without a problem. Most strap failures are users fault. Doing things like not cleaning the mud off them (the dirt acts like little razor blades and cuts the fibers of the strap). putting them up wet and they start to rot. Leaving them in the sun weakens them. Store them dry, clean and in the dark and they will last a long time.
    Any way here is the list we require to be in every vehicle and I can asure you I have used every bit of it multiple times.
    Georgia Bounty Runners 4WD Club, Inc.
    Mandatory Safety/Recovery Equipment List
    Name ______________________________
    Vehicle: Year ___________ Make _____________ Model _________________
    Group A (must have to go on any club run)
    ___ ___ Valid drivers license
    ___ ___ Vehicle insurance meeting State minimums
    ___ ___ Current State tag
    ___ ___ Seat belt for driver and all passengers
    ___ ___ Rollbar/Rollcage for all soft top (also recommended for any other removable tops)
    ___ ___ Battery securely bolted down (no rope or bungee)
    ___ ___ Approved front and rear tow points (hooks, receiver, tow eyes)
    ___ ___ Loose-fitting leather work gloves
    ___ ___ Jack, lug wrench, and spare tire of a comparable size to the vehicle tires
    ___ ___ Fire extinguisher (min. 2 l/2 lbs dry chemical ABC rated)
    ___ ___ First aid kit (bee/insect sting care should be included)
    ___ ___ Snatch/Tug strap (2" x 20', sewn eye ends without hooks, minimum 20,000 pounds)
    ___ ___ Secure all loose items (including coolers gas cans, tools recovery gear etc)
    ___ ___ Flashlight with extra batteries
    ___ ___ CB radio with 52" or short antenna
    ___ ___ Emergency medical information for all vehicle occupants (green sheet) consisting
    of doctor's name, phone number, insurance company/policy number, special medical
    conditions/allergies and emergency contact name and phone number(s)
    Group B (must have after becoming a member for three months)
    ___ ___ Tree-saver strap (min 2" x 6")
    ___ ___ D-Clevis and/or shackle (min 5/8")
    ___ ___ Chain with grab hooks at both ends (min. 5/l6" x 20')
    ___ ___ Hand winch or come-a-long, 2 ton (or 4000 lbs) minimum
    ___ ___ Jumper cables (long and big)
    ___ ___ Shovel (min. l2' handle)
    ___ ___ Axe (24") and/or tree saw
    ___ ___ Flares and/or road reflectors
    Group C (recommended)
    ___ ___ Pickax or Mattock
    ___ ___ Short chain with grab hooks at both ends (3/8" x 6')
    ___ ___ Hi-Lift jack, with accessories (wood base, extra chain, etc.)
    (1) Inspected by ______________________________________Date _______________
    (2) Inspected by ______________________________________Date _______________
    IF YOU HAVE ANY QUESTIONS, SEE THE VICE PRESIDENT/SAFETY OFFICER
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Grim, what's the 20' of chain requirement about? Just curious
  9. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    No bungee cord to hold the battery??? /forums/images/graemlins/shocked.gif
    I'm in trouble /forums/images/graemlins/eek.gif
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Chain is what he uses to lift his axle with only a 48" hi lift and flexy suspension.
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I understand what you're saying there, but a 10k lb rachet strap does just as good as a chain, and weighs a hell of alot less/forums/images/graemlins/wink.gif
  12. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Good for when you need to rig a Come-A-Long. If you rig it w/ a strap the strap will streach and the C-A-L will run out of travel before you move the truck.
  13. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    What is in my rig at all times.
    Shovel
    axe
    come along ( a good one)
    trusty high lift
    30' snatch strap.
    a 4 , 15 and 25' chain
    chain binder
    2'x3' expanded metal screen for putting under the high lift
    tree saver
    Chocks
    Having attach points front and rear is a major plus.
  14. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Well, first you need to address the issue of survival gear and stuff you need to bring along.
    We require front and rear tow hooks and a fire extinguisher in our club. Our club usually has no fewer than 9 vehicles going out so there is always someone that has something you can use.
    I carry enough tools to fix anything I can on the trail. That includes an alternator belt/radiator hoses and several different sizes of fuel and vacuum line. Someday I'll probably carry universals also. I also carry two quarts each of ATF and oil. I carry a gallon of 50/50 antifreeze and a half a gallon of the infamous "emergency gas" that you can buy at the department store. I carry a pair of 20' 2 gauge jumper cables. I also carry an assorted backpack of junk that contains road flares, tire patches, tire plugs, radiator "pellets", tapes, and zip ties. I also carry some large zip ties (30" long). I have two first aid kits and carry a large blanket with two lighters and candles in the middle of it. Somewhere I have toilet paper, garbage bags, and leather gloves too but I don't know if they're in the truck anymore. You always need flashlights also. I've got two, one mounted on each door. Always have the stuff to change a tire even if you don't carry a fullsize spare. Someone else probably will in your group and they might let you borrow.
    For trips only:
    I carry a 4 ton come-along and 12' of 5/16" chain with one tow hook and one grab-on-itself hook on the other end.
    A snatch (recovery) strap good for 30,000lbs. Girly trucks like Toyotas have a hard time getting fullsizes out of holes if you get the 40,000 or 60,000lb straps.
    I also carry a real shovel, a real axe, and 5 gallons of gas.
    Depending on my mood I take my 5 gallon portable air tank with me just in case.
    It's a good idea to have a cellular phone (and CB radio). An elaborate first aid kit with the bee shots would be nice but as far as I'm concerned anyone that has allergies should be taking care of themselves.
    Everything in the cab needs to be securely fastened. I recommend the same goes for stuff in the bed of a pickup (if you've got a truck) even though I usually leave my shovel, axe, and chain loose. The rest gets fastened but the shovel and axe get used often.
    Someday I'll carry a hi-lift and I highly recommend getting yourself a 60" hi-lift jack. If you get a come-along don't bother with one under 4 tons. They're a waste of time and will just bend or break. My 4 ton one is a bit on the wimpy side in my opinion but I have used it to lift up a truck before. Of course, a strap should be first on your list (30'x3" seems to be universal). If you get a come-along you'll want a high test chain (preferably 4,000lbs or more which is pretty much 3/8" or bigger).
  15. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    hilift isnt always a "required" dont-leave-home-without it type thing... some rigs are litterally to tall to highlift, for example. My 48" hilift is pretty much useless even with my 35s on... with the 39.5s even with a 60" hilift you'd be pushin it. If you use the old chain between the axle and frame trick, it helps a lot... a rig with any flex will be able to keep all 4 on the ground in spite of a hilift sometimes. guys who can ramp at 1000 and stuff...yikes. pretty much need to connect the axle and the frame somehow (chain trick) or use a jack that goes under the axle itself.
    j
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The Hi lift is usefull in many ways other than changing tires, and as you stated tying the axle to the frame with anything will make it easy to change the tire even with a 48" lift and no matter what size tires.
    I have used it to winch myself out before I got the winch.
  17. racercrazy
    racercrazy 1/2 ton status
    Dec 29, 2001
    145
    O\' Fallon, MO 63366
    Thanks for asking the question. I needed to know myself. Thanks guys/gals for the great replies and helping newbies out. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. pplblazerdude
    Jul 18, 2002
    242
    Would it be better for me to get a come along or a hi lift to winch my self out because i cant afford a winch and all that junk right now or should i get both of them.
    Thanks Clint /forums/images/graemlins/k5.gif
  19. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Get both, you could be in a sot you need to lift w/highlift and keep it from falling downhill which you could do with the comealong.
