what rims to get?15 16 or 16.5
Discussion in 'The Garage' started by Jonny-K5, Aug 14, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    im upgrading to either 3/4 or 1 ton setup and im not sure what rims to get. i will be getting new 35s so changing rim size is an option. should i get 16 or 16.5? or stay 15 and grind calipers if i get a dana 60? also what width rim should i get? im gonna get 35x12.50 bfg at.
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    15's are better to air down, more lip on the rim
    I only run 16.5's B/C i use US hummer beadlocks.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i was thinking 16.5 causs i'd have less sidewall flex on the road, my truck is a DD. am i going to notice a difference?
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    More tire choices with 15" too
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Both 15 and 16.5 have good tire selections.....
    16 is quite limited. Check out a typical 4WPW ad sometime, and you'll see what I mean.
    15" = caliper grinding or crazy backspacing
    16" = poor tire choices
    16.5" = no safety bead
    Each one has at least one drawback (and workaround)....I'd spend some time looking at the 17" stuff now too, it's going to get more and more prevalent (from what I can tell) so if the tire sizes make sense for what you're doing, it could be yet another way to go.
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    17's are alot of money and im on a budget. i didnt know 16.5 had no " safety bead" . what excatly is a safety bead and why dont they have em?
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    safety bead keeps the tire from slipping off the bead area of the rim at low pressures..16.5s suck..you let all the air out and the tire pops off the rim..you can get most tire sizes in 16...
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i bought new 16.5's lol. thats what i like. I like aluminum wheels and one day would like a D60. Cant have aluminum 15's on a 60. 16's dont have all the tire sizes. My opinion, if you run rocks, or where you will need to run 5psi, and dont my steel wheels, get 15's. Get 16's if you want a bit bigger wheel, possible aluminum wheels over a D60(im not sure), but dont mind the limited tire selection, and need the air downability(whew i need help lol). Get 16.5's if you are like me, like aluminum wheels, dont need to go below 12psi, and want less sidewall flex, and still have a good tire selection. 16.5's fit my needs. But others swear by the 15's and swear at the 16.5's.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    why don't 16.5s had a safety bead?????
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    hope this helps, it's not much [​IMG]
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Poor tire choices in 16"? Try getting a Goodyear MTR in a 16.5....
    I have seen a lot of the newer designs aren't made in 16.5" as I have a set of them for future use. Many of the tires I would like to try aren't offered in this size.
    Pro Comp X-Terrain
    GY MTR
    Trxxux MT
    etc.
    Just my thoughts....
  12. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    I just got a set of the Super Swamper IROKs in a 39.5 x 13.5 x 16 on a set of 16x10 black crawlers. Excelent tire, perfect size and safety bead to boot. I was not too thrilled about grinding to fit my old 15's, so I shopped for quite a while untill I settled on the IROKs.
  13. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i dont run below 20 psi now so i dont plan to go in the teens if i do go with a 16.5, so i shouldnt have a problem with popping the bead. if i run a 12.50 tire, should i go with an 8 inch rim? or a 9.75-10.0? what backspacing are you all running? i want my rims tucked in as much as possible and want to get some ideas, thanks
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I say buy the 15'a with no more than 3 1/2" backspacing. Tires for 15s are cheaper, there is a good safety bead and you won't notice the difference between the sidewall on a 15 and 16.5. Also, 15" rims are cheaper.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Rim selection for 15" 8 lug wheels kinda sucks. That's what I'm looking at myself right now. I bought 15's for tires, but haven't been overly thrilled with the choices of wheels avalible in a 8 lug flavor. Probley just get the old trusty white wagon wheels.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I got. Hit them with Krylon flat black and they're good to go. I used to have chrome but I prefer black for my truck now.
  17. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    why only 3 1/2? doesnt that make them stick out too far?
  18. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The more backspacing you have the more grinding you will need to do. 3 1/2" doesn't stick out much. Decide what tire you want to run (brand/size) then pick you rim size. Otherwise you may end up w/ rims that won't fit the tire you want.
  19. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My choice for rims would be 16's. There are getting to be lots of tire choices for the 16" rim, until you get to around the 38-39" range or bigger and then they drop off. But I expect to see more sizes keep coming out. 16.5 rim tire sizes are really starting to drop off, I think BFG only makes maybe 3 sizes for the 16.5's but has probably a dozen sizes for 16's.
  20. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    well im not going any bigger than 35, its my DD and i think 35 is too big. why are 16's so much more per tire? does anyone think they will go down ever? quite a bit more than 15.
