What rims with 8 lug?
Discussion in 'The Garage' started by Klef72K5, Jan 25, 2003.
  1. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    What rims with 8 lug are you guys running? I'm wanting a 12" wide rim, 10" as last choice. I'm wanting to run the Baja Claws 35x15.5x15. Is there any good 15" rim for a 8 lug?
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I hope you don't mind steel wheels, If your going to stay with the 15's and go up to a 8 lug Steel is the only option.
    Eric
  3. Klef72K5
    Apr 8, 2001
    249
    everything is still in the air. I just bought my CUCV axles and I'm wanting a wide tire. I haven't seen many....if any 16x12" rims. Anyone know of any? If steel what brand? I've read other post that said the Bart rims have alot of runout???
    I'm just open to suggestions. After looking over the Dana 60 reveiw I thought about converting my bolt pattern.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you're going to run beadlocks, you gain an inch or more when you put the beadlock on a rim. My 16x8" rims are now 16"x9"+ with champion beadlocks on them.
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Weld wheels make a 16x10 with beadlocks. 8 lug for $312ea at Wheels page
  6. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I can't say about Bart Wheels, But if you are going to think about a 16in wheel just about everyone has a 12in.... Well now that I'm looking a 4x4 mag it doesn't show much of anything but when I was down at our local tire shop he showed me a 16x12 steel wheel I want to say it was a US Wheel but I'm not sure about that. You could look at what Rockstomper has they sell wheels up to a 17in but they are all steel.
    By the way have you read the write up on those tires yet? They were saying that they mite get only 10 to 12000 miles out of those tires.
    Eric
  7. Klef72K5
    Apr 8, 2001
    249
    Do you guys that have the 8 lug on a 15" like it? How is the fit? How much grinding was there? Any pics?
  8. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well you said your going with the Mil. setup so I'm guessing you have a D60 for the front right? then you need to read This . That write up will give some insight to what you have to do to run 15in wheels on a D60. Now if you were going to run 15in wheels with a 3/4 ton D44 8 lug, You mite not have to grind anything but I've some just lately that did have to. Either way it's Very close.
    Eric
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Your probably gonna have to go with welds there expensive but there REALLY nice looking and REALLY strong.
  10. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    those black rock crawlers are steel right? what about those chrome ones?
    thanks,
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    all rock crawlers are steel
  12. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My black rock crawlers are steel.
    15x10 8 lug.
    I like 'em a lot.
    Had to do grinding on both my old 3/4ton front and also my current dana 60.
    -- Mike
  13. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    oh but 8lug 10bolt fronts you dont need to grind right>? or 14bff rears?
  14. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    14 bolt rear don't need to be ground period - drums or disc, 15" wheels, any backspacing it doesn't matter - lots of room.
    My 3/4ton front was an 8-lug 10 bolt. With my 4"ish backspacing I had to do a good deal of grinding.
    It would be the same with an 8-lug Dana 44.
    I believe I had to do less grinding on my Dana60 than I did on the 8-lug 10 bolt (with the same wheels) but others on here have said no way so maybe I just remember it wrong.
    -- Mike
