What say ye of this hydraulic ram? Found another one...
Discussion in 'The Garage' started by stallion85, Feb 22, 2007.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I would definately look for a ram that had replaceable ends. I couldn't tell if those were or not.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hmm, another question. The actual end with the rod.....does it spin around? So I would just need to cut and turn the end that will go to the axle.
    How did you driveway mechanics cut and turn the end? With an angle grinder......?
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    That one looks a lot better than the ones they used to offer. Nice find.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    That looks good...but they don't have any...
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    LOL, I saw that too. But I'm sure they'll restock it. The one i thought about getting once, said dicontinued ... so I imagine they'll have more.
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I must have bought mine just in time!
    I picked that ram up from them a month or 2 ago for my 71.
    I plan on taking my portaband to the fixed end and rewelding it on 90 degrees apart so the fittings work, just haven't gotten around to any of it yet.
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    :doah: :(
    Didn't even notice that!
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Depends on how you mount it. Yes you could just limit travel. Could you wait a week or two and see if they get some back in stock?
  11. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
  12. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    How could I limit it? I would rather not wait a few more weeks to order the other ram. If need be i could get the one like Jethros.
    Also what would the disadvantage be of a 2X8X1 Ram? It is about $50 cheaper....
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Hydro power comes from surface area of the piston. Calculate the area, multiply it by the pressure, and get force. The surface area on the rod side is the total surface area minus the area that the rod takes up. Go to a big enough rod and you won't have much force on that side.
    I take it this gets driven to or from trails? If not, you might wanna consider a tractor ram. 2" bore, little slow with a lightly modded pump but unless you're bombing desert roads it's not much of an issue.
  14. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    She's a trailer queen. So a 2X8X1 would work fine with a modded pump? If so I am getting it. They have one with clevis ends for $59!
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Easy there Seabiscuit. Consider picking one up a Chief or similar from your local TSC or equivalent. That way if you screw one over on the trail you'll likely be able to find a direct replacement locally. After you pay freight from surplus center they'll likely be the same price.
