What shims have you used??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Sep 29, 2003.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Got my Echobit flip ready to install... Mike suggested 5 deg shims.. I currently have a set of 4 deg shims.. If ya have installed the Echobit flip what deg of shim worked for you?? Its goin on a '76 K5 w/12b. I'm only going for the 4-5 inch lift, going to remove those /forums/images/graemlins/angryfire.gifblocks...
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If you have the 4 degree shims already...use 'em.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    If you do some simple math, a 4" shackle flip changes pinion angle by about 8 degrees. If you lower the transfer case, 4 degree might me OK, but pushing it. An angle finder is a great tool. I say try it and see.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No shims for me and works fine. /forums/images/graemlins/smile.gif Pinion angle is pretty high but no driveline vibes.
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    After dropping the transfer case, and using 5 degrees, It minimized *most* of the vibes, but I still had them. Then again, I have a slip yolk, I dont think you do...
  6. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I did a homade 5" shackle flip on mine, didn't drop the x-case, and used no shims. Seems about perfect for a rear cv driveshaft, which I still need to get. But even without the cv, no vibes.
  7. rcpilot
    Feb 22, 2002
    507
    Central Cali
    I have a new drive shaft and it is a slip yoke.. the 4" rancho blocks under it now look about 4 deg.. the pinion tilts slightly up.. I'm going to use the 4's first this week and I'll test it out.. seems 5 deg are a little hard to come by.. both 4WheelParts and National Spring in San Diego have to order them... so we'll see /forums/images/graemlins/thinking.gif
