what shock's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by oldschool75, Nov 9, 2001.
  1. oldschool75
    oldschool75 Registered Member
    Nov 9, 2001
    7
    so. cal.
    what shock\'s
    WORKING ON A 75 GMC JIMMY. I WILL BE USEING IT IN ROCKY DESERT MOSTLY TRAILS BUT SOME JUMPING. I WANT TO EITHER DOUBLE SHOCK THE FRONTS OR MAYBE SINGLE SHOCK WITH EXT RES. WHAT'S BEST ?
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Re: what shock\'s
    First lay off the CAPS, second fill out your profile so we can ALL help you, and third ... rancho 9000's are adjustable from very soft to very firm and doetcsh tech (sp?) makes a good "washboard" shock. Hope that helps alittle bit [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    GO BUSH
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: what shock\'s
    Bilstein, Sway Away, Kings. If you're going desert running, spend bucks on the shocks. Stay away from the twin tube and goe with the monotube shocks that I listed above. Shock fade is what'll kill ya and that comes from heat buildup which comes from a lot of shock movement in a short time.
    Bubba Ray Boudreaux,
    "If I had wanted a plastic ride, I'd married Pamela Anderson."<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
