What should be connected here?
Discussion in 'The Garage' started by BigCountryx, Aug 19, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    It looks like a vac line should be connected here, but I'm not sure. I don't know what it would do if it were connected anyway as it seems that the vac line coming into the switch and the line coming out to the EGR should be all that is needed. I get a Check engine light from time to time, I've never pulled the code, but I was just looking things over looking for something obvious.
    BTW - when pulling codes, do you have to leave the truck running once it throws the code in ordr to check it? Every time I get the ses light and kill the engine, it goes away by the time I restart it and stays off for quite some time.
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    That's the EGR control solenoid and there shouldn't be anything connected to the top port. When I replaced mine it had the top port covered up.
  3. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    that is an air vent for the solenoid it should be left open at one time there was pry a small foam block over it
  4. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    Yup my new one was covered up with a chunk of foam.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Mine is open also. And has been for a long time. Just recently I put a long piece of vacuum tube on it to run to high places.
    I've seen some with a cap on them that looked similar to an axle vent tube cap...
  6. puckhead
    Jun 17, 2005
    112
    colorado
    BTW the way to pull codes is to have KOEO (Key On Engine Off) with the jumper installed in the ALDL (the plug under the dash) if you have a very intermintent code it may not trip a permant code so you may need to wait for the light to come on more often
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    It is in fact a vent.....but where is your MAP sensor at????
  8. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Talk to me, do I need something that I don't have?
  9. puckhead
    Jun 17, 2005
    112
    colorado
    your map sensor is there otherwise it would run like crap and have a check engine light all the time. Besides i can see the screw that retains the map sensor and the line that feeds it also so your cool man no worries the map sensor mounts to the underside of that bracket and has a single vaccum line running to it with a 3 wire plug the plug is usually green.
  10. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    I don't see the map sensor or the line that feeds it anywhere in that pic :dunno:
  11. readymix
    May 30, 2004
    6,706
    26
    I don't see any part of the MAP in that pic or the wiring or the vacuum line. Having said that, if it was really not installed your truck would runn horribly. I am sure it is just in a different spot on your truck.
    Look at the back side of your TBI between the fuel lines. there should be a vacuum line attached there. The other end goes to the MAP
  12. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Well, the MAP must be there 'cause the truck runs like a top. I'm amazed by the nearly 200k on the od. You would never gues it by driving it! (probably just jinxed myself...........damnit)
