what should be connected to this (pic).........junction on firewall
Discussion in 'The Garage' started by jakeslim, May 4, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    What should be connected to this? I found a cut wire connected to this and I want to be sure all is ok. I currently have just the two wires connected to it.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On my burb, the side that your 2 wires are on i have one wire going to the starter and another wire going to the alternator. On the other side(drivers side connection)it goes to the backside of the fuse box on the firewall. IIRC its part of the ignition circuit /forums/images/graemlins/thumb.gif
  3. dyeager535
    26,982
    191
    Should be the wires from the starter to the fuse panel connector, and in some cases factory towing package wiring.
    The two wires visible should come from the starter, and two wires should tie into the fuse panel connector from that junction.
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    hmmm...everything seems to work...is it necessary to connect it to the fuse block on firewall?
  5. dyeager535
    26,982
    191
    Well, I thought it was only the two wires from the starter, but it could be from the alternator too, or instead of, either of those wires. Been awhile since I messed with mine.
    If everything works ok, I'd probably forget it, but I would first make sure that anything thats supposed to have a fusible link, does. Or else you could have a nasty meltdown.
    For one thing both red wires off the starter (not the + batt cable) need to have one each as I recall, and not sure if there are usually two more fusible links on those wires at the junction also.
    Have to venture a guess that someone rewired the thing. When messing with fuse panel feeds, I'd want to make sure the fuse panel is at least protected by the fusible links.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    on my truck nothing works without those two wires (and the scome from the other side,, and the third wire goes to the airconditioning solenoid. . .weird eh?
  7. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    on mine starter and AC relay thingy
  8. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Does your fan work? The 3rd wire on my rig runs to the heater/AC relay.
  9. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    That is where the a/c system gets its power...the two wires that power that junction block should be fuse links...provides power across a shunt to power the a/c system.
    DW /forums/images/graemlins/usaflag.gif
  10. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Per my 1990 service manual this is the "Accessory" conector. This is were you connect the charging cable for the second battery and what ever else you can think of. It is fed directly from the alternater.
    dan..
  11. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    WHOA! That's where you're supposed to connect a second battery's positive cable to???? /forums/images/graemlins/ears.gif
    Can anyone else verify this???
  12. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    is this confusing yet!? I quess i will leave as is.
    1)My heater is working fine.
    2) the truck did not come with air
    3) the battery is charging
    4) the starter works
    5) All electrical is working.
    Thanks for all the responses /forums/images/graemlins/cool.gif
