what should i ask for my 91 k5?
Discussion in 'The Garage' started by WakeBoard&4X4er, Aug 26, 2003.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    Lee's Summit, Mo
    i an think of just stripping my K5 and building somthing else but not sure what.
    This is a list of things that i can think of but have no idea on what to ask for in prices.
    Winch 8000i roller 2 remotes good shape. W/ mount
    4 head lights all working for 91
    Bullet grill
    350 tbi top to bottom lines and tank
    Oil cooler
    Tranny cooler
    Tranny 4L60 * (3.06:1 First Gear)
    T-case NP241 (2.72:1 Low Range)
    All red seats, carpet, belt, head liner
    Rear gate with window and good motor no rust but a dent in it.
    Hard top w/ tented sliders or just windows.
    Rear axle with 30 spine 10 bolt 4.1, true trac, Yukon gears and axles
    Front axle 10 bolt with 4.1 true trac, 44 flat top outers MOO x-over arm, rock stomper bent drag link 2 wd box
    4 wd box.
    ord brace
    7 35 tires and rims 5 the same 2 miss match. (5 dunlops 4 75% (one with a slice) 1 99% (plug) 2 Big O 60% and 10%. Spares on Wagon wheels, others on 589s.
    abs brake set up.
    tilt steering.
    4 inch springs front BDS
    0 rates
    Bolt on Flips 5.5 lift
    2 sets or rear axles shafts 30 spline
    2 full front axles
    3 rear d shafts 241 slip
    1 front d shaft 241 cv
    b&m tranny temp set up
    Spare tires holder (inside)
    1350 yoke for a 10 bolt
    Fuse Box
    Stock radio with eq and tape
    Glove box
    Gauge cluster (all working)
    Power window set up
    Power locks set up
    Power mirrors
    Tail lights
