What should I do? (8 or 12 inch)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Feb 18, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Should I or shouldnt I?
    I already have an 8 inch lift. I could go up to 12 real easy. Driveshafts are not made yet. Just would need to get new front springs.
    But, should I?
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Unless you plan to run bigger which i see no reason to, 44's are gigantic, id just keep the 8" lift. And save the $$
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 6"susp, 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
  3. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    IF ya like to slop around in the mud and deep holes go for 12, if you like cruising the vertical face of mountains stay with 8. MHO.
    Jamie
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Yeah, I am just muddin. No rocks or such around MI. Although, they are building a rock garden a few hours away.
    Probably just stick with the 8 and some trimming.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend has 12 and 3 and he still has to trim, so pick your poison.
    Tim
  6. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    Four by Ken, Where are they building a rock garden? I live in SW MI, so I am kind of curious?
    "We all gotta go sometime.... Race ya"
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I started a new thread about the rocks... check it out.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    off the shelf 10-12" springs are junk
    formerly 77chev
    still a jerk though
  9. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    well with a 12" its stiff . man is it stiff. And their a bit of sway. Least on the Chev 1 ton I was in with 44's. Eww hated ruts. As for 12" needed for muddin. well I have 11" total with 38's and it chews it up nicely. tires are narrow and dig into the thick hard clay at the bottom of the pit here in Oregon. and with 12" your looking at a adj drg link also possibly even a more severe dropped pitman arm. Serious brakeline replacements, Longer shocks for sure and possibly some electtrical wiring mods. Also that big of tires you are looking at very common breakage. If I go 44'2 im putting my 2 1/2 ton rockwells to good use.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    you should do 21.5 inches of lift with no front driveshaft...
    haha... just saw another post...
    sorry...
  11. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    My best friend has a '79 K10 with one ton axles, 8" Skyjacker suspension lift, and cut fenders. This clears 44" Swampers with no problem. I personally don't see a need for 12" suspension, IMHO. Your truck will sway a lot more and steering correction for that much lift is hell. Not to mention driveshaft angles, spring stiffness, etc. I would stick with the 8" and cut fenders. Hope I didn't steep on your toes, i just don't see the need for 12". Hope this helps.
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs, ORD crossover steering
  12. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I have decided to stick with the 8 inch I already have on there and just add some body lift and fender trimming.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
