What should I do about my rear suspension?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 25, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a longbed pickup.
    The front has a 6" lift with ORD shackled for 1/2" lift and a Dana60 which adds about 3/4" lift over my older front axle, so it's about 7" lift.
    The rear has stock drooping springs(- 0.5") with an add-a-lead (1.5") and 4" block. Total 5" lift.
    The front is too high.
    I've thought about a shackle flip, but that's only 4". Should I get 4" lift springs and go with the shackle flip?
    What do you guys think>?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    www.springersuspensions.com
    i have it setup on my truck, and i have seen other trucks running it. as soon as i saw it up close i HAD to have it.
    cool $hit marv makes.
    check it out.
    Grant
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Shackle flip 4", 2" springs, and 1" zero rate would get you level.
  4. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Im in the same boat as you, i have 6" front and soon to have ord zero rate, in the rear i have 4" shackle flip with stock springs, overload flipped, add a leaf and 1" or so block. The fron sits higher right now an thats with out the ord zero rate. So im thinking 4" rears should be good and will get her to sit level.
