What Should i do to improve the chevy 305????
Discussion in 'The Garage' started by Capnscoop, Mar 25, 2007.
  1. Capnscoop
    Capnscoop Registered Member
    Mar 25, 2007
    43
    South Florida
    what should i do to improve my stock 305(1986)??? any suggestions im not looking to break the bank......thanks...also were should i buy new rubber seals for my doors windows cab ect???
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    drop it in a 1500 lb car, it'll drive NICE and fast then,,,,
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Intake, carb and exhaust...
    Also see Classic Parts of America for your window seals
  4. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    You could try a throttle body spacer, aftermarket exhaust, k&n air filter. Or just take that 305 out and throw in a 350:wink1:. that'll get the job done for sure.
    Try here for those seals http://www.lmctruck.com/
  5. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    Just do basic's, intake, carb, exhaust, anything that can be bolted onto a 350, although people will tell you that the 305 isn't a good motor, they run very well, and with money can be made beastly, but a 350 is always a better motor in the end, with the mods you do to the 305, you can bolt them onto the 350 later on. Have fun.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Add 45 cubic inches.
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Attach a chain to it. All a 305 is good for is a boat anchor. :D
    Seriously, it would be cheaper to install a new 350 crate engine than try to improve power in a 305 without breaking the bank.
  8. dyeager535
    26,979
    Make sure it's in good tune. Plugs, wires, vacuum lines, etc.
    Nothing really wrong with a 305, except the size and inherent design issues. Without tons of money, it's pretty hard to "wake up" in a truck, the engine is too small for this large of a vehicle.
    Biggest bang for the buck IMO for a 305 equipped truck is gearing. If yours are 3.08's (common and likely) then swapping to a numerically higher ratio will make all the difference in the world.
  9. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    4,089
    399
    NEBRASKA
    Going from 3.08s to 4.11s made my 305 a rocket ship in comparison.
  10. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    x2 add 45 cubic inches.
  11. shockline
    shockline Registered Member
    May 10, 2006
    51
    Powhatan Virginia
    I had a 305 in my 84 K5, and it was nice for DD, but for towing or anything fun it was not fun. I switched mine out for a 383, it should be done by Easter.
  12. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    x2. always thing ahead to the day when you add more cubes. 305 isn't a terrible engine, just not the best choice from gm.
  13. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    cam swap, cs1062r at www.northernautoparts.com it will wake that 305 up, also a performer rpm intake,or just a performer, and some headers, also if you could take the heads off and do a diy exhaust valve cleanup, that would be the best mod ever to a 305, im runnin 305 heads on my 327, they lack the top end from the get go put a little porting in them and its a good effiecient head, the exhaust port is the killer, the 305 took my 83 camaro into the 7.9s range in the 1/8th mile which is way fast for a 305
  14. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    though the 305 is not my choice of engines, I have nothing bad to say about them. hell right now I would love to have one. Ive got 3 trucks and none of them have a motor.:( Id use a 250 inline six if I could find one in good shape.
    as far as 305s go, there is a guy I work with that has an 81 with 35s and stock 3.08s. he built a 305 with a big cam, ported heads, headers and an aluminum intake that will smoke the tires without power braking it.
    the only real problems I see with them is like was said, they lack the cubes to make a lot of power and I was looking at rebuild kits, since Im gonna have to rebuild my motor, I can get a kit with everything I need to do a basic re-ring and replace bearings in a 350 for $120. the cheapest one for a 305 was about $250.:eek1:
  15. gibby2268
    gibby2268 1/2 ton status
    Jun 6, 2006
    553
    Middle TN
    My solution: Drive a 99 Nissan Frontier with a four banger and auto tranny around for a while, then the 305 will feel like a big block, baby!:D :woot:
