what should i do with this slipyoke 205
Discussion in 'The Garage' started by k5texan, Aug 19, 2002.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    is a slipyoke 205 worth keeping. should i just buy a sye kit or sell this one and find a fixed yoke.
    thanks
    jared
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    See if the junkyard will trade you. They did for me.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    if not, it would make a really interesting center piece, or ashtray. but that's if the table could support it
  4. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    What year is it??????? Sell it to me and find a fixed Yoke /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just get the parts from a fixed yoke t case from a sm465 trans which are a dime a dozen and convert it. It is only about a 1/2 hour job.
  6. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    What is the difference between them? Wouldn't a slip yoke 205 be an easier replacement for a 208 or 241, or is it a totally different animal?
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You'll have to get your driveline redone anyway so you might as well hold out for the fixed yoke. You'll thank yourself when you break your rear driveline and you can still drive.
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I was looking at an 80 model truck with the sm465 205 combo...so this one would have had the fixed yoke rather than slip yoke?
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The '80 shortbox that I used to have had the slipyoke version of the 205. You never know these days, it could have been swapped out.
  10. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    An 80 model will not necessarily have a fixed yoke. My truck is an 80 K10 that originally came with a 350/465/205 and it was a slip yoke type. GM started using slip yokes around 79 or 80 so you'd probably do better looking for an earlier case.
  11. k5texan
    Aug 1, 2001
    119
    Flint, TX
    this one is out of an 89 1 ton and is mounted to sm465. and i got the whole truck for the axles and and fuel injected 454 and was going to part out the rest so i was jut wondering if the 205 was worth keeping for later use.
    thanks
    jared
  12. 78Blazer
    873
    Michigan
    How much you want for it then??
  13. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I haven't had any problems with my slipyoke 205. It has been punished alot and hasn't let me down yet. Now that I think about it, it's the only thing in the running gear department that I haven't had to replace or repair. /forums/images/icons/cool.gif
  14. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I own two 1980 K10's, both came with NP205 slip yokes. I bought a 4 speed from an '80 Blazer a few years back, guy threw in the transfer case, it was also a slip yoke. Every NP205 I run across is a slip yoke dammit!
  15. k5texan
    Aug 1, 2001
    119
    Flint, TX
    i got a guy coming to look at it this weekend if thst does not go through i will let you know, but if we have to ship that will be expensive.
    jared
  16. Super_S
    Super_S Registered Member
    Jul 30, 2002
    11
    Katy TX (west Houston)
    My 205 had a slip yoke on it when I got it. Later on down the road I found another 205 in a local take-a-part so I picked it up for $100. I robbed the fixed yoke off of it and threw the slip off mine on to it. So I guess I have a $100 fixed yoke kit. But I can sell this other 205 to some one with a 208 as a simple swap in. I ran with the slip for about 3 years though. To swap that rear housing is really easy. If that guy doesn't buy that trans and case let me know I would be interested too, and I can pick it up.
