What should I do with this?
Discussion in 'The Lounge' started by ryan22re, Jun 8, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Got this from work last night. Came from an injector test stand. There were two of them, both identical, one held diesel and the other (the one i got) held hydraulic fluid. Capacity is 75 US gallons and is made of aluminium. A little too big to run as a fuel tank, and is un-baffled inside. Was told, it cost around $650 to have it made three years ago. Came from here: http://www.metaltanks.com/
    Whatcha think?
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Purdy!!! :wink1:
    Will it take 120 PSI?
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I doubt it. Not pressure rated, only fluid storage.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Beer carrier for ECBB 06!!! :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,021
    849
    Pinckney, MI
    Very good platform for a new grill :D or small roaster
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Full hydro resivoir
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    pretty sure it wont work for a grill, the Alum. will melt
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    kegs are aluminum, arent they? i cant count the number of keg grills i've seen.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Pretty sure the propane grill I have at home is aluminium.
    Would need a pretty big burner though.
  10. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Looks like an excellent solvent tank to me. Wash, wash, parts, parts, lotion, lotion, hands, hands.
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I agree. Cut a large access door. Use the siphon tubes with spray heads attached. Mount a fluorescent light inside at the top, or remove the filler cap and put a spotlight in there. Good Score!
  12. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Hmmmm....:thinking:
    Now that's an idea.
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    above ground fuel tank for your hurricane genset....
    Very nice tank... me.. I would baffle it... and use it for a fuel tank... 1 minute with the plasma (evacuated of course).... about 15 actual weld minutes... 25 dollars of aluminum for the baffles.. make a couple of mounts...
    If it was here I think my logging buddy would buy it in a second
