What should I do?
Discussion in 'The Garage' started by bonanza, May 14, 2005.
  1. bonanza
    bonanza Registered Member
    Oct 18, 2004
    55
    Sterling, IL
    I have a 78 K20 frame that I'm putting a 79 K10 body on. This is gonna be mostly a driver/truck puller/fun truck. I have a 400 out of the K10 that I can rebuild. I already have the heads done, but I need to rebuild the shortblock, but there's a chunk out of the block by the starter bolt hole. Or I have a 1992 350 that I could do a 383 with. So I'm asking you, should I piss with the 400 and have the block welded, or should I put a crank and pistons in the 1992 350, roller cam and vortec heads?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can avoid patching the block by using an old cast-iron bellhousing and the matching bellhousing-mounted starter.
    I had a co-worker that did some 383's in customer's vehicles. They are a costly endeavour. IMO, buy a complete 383 shortblock instead.
