what should i do
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jul 9, 2001.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have a 87 k5 and i replaced my water neck but the problem i ran into was the bolt holes on my intake manifold are stripped so i cant run the truck without anti freeze leaking so what can i do would thread repair work or do i have to get a new intake manifold?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd give Form-A-Thread a try before going the new manifold route. You may also be able to tap it out to the next size, and ream the water neck.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    I had the same problem on an 87 caprice with a 305. It never sealed right when i tried to fix it. It just kept leaking. You might be able to drill it out and tap a bigger hole. I started looking for another manifold until a lifter grenaded and took care of my problem.
    Craig
    "Why is there a <font color=red>watermelon</font color=red> here?"
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Well you can get a tap and die set and drill out the holes and tap new threads for the next size bigger bolt. Or you can get a heli coil with the same size threads as stock from a auto parts store. but You will still need to drill it out and tap new threads to install the heli coil. If you dont want to do any of the above. Pull the manifold and take it to a machine shop they will be able to fix it for around 20-40 dollars
    <font color=orange>GOT HORSEPOWER?</font color=orange>
  5. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    You can get heli-coils at almost any parts store. Once you have these in, you won't ever have to worry about the holes stripping out again.
