What should i get off a compression check from a 10:1 355?
Discussion in 'The Garage' started by dirtwarrior17, May 6, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Just need to know what kind of psi i should be looking for out of a compression check on a 10:1 355.
    thanks,
    shane
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    10:1 is a pressure ratio right... so it'd be ambient pressure times 10 i would suppose ;)
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    take the reading that you get and divide it by the atomspheric pressure. For example if it is 14.7 psi when you do the test you should get around 147 psi on the test. This is only a rough estiment other factors like valve timing can effect the readings. This should get you close though
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    if i remember right from when my engine building friend told me.if you have at least 120 or more per cylander you are still alright and dont need a rebuild yet.
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    it depends a lot on current weather and altitude too (less air to compress at higher altutudes and in low pressure weather systems)
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Does anybody have a psi off a 10:1 motor... Im looking for a psi "ballpark"
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i said the ballpark would be around 147 psi at sea level.
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    OH.... does it get higher or lower with more elevation?
    I've heard people getting 160 psi on stock comp so i guess they spun it too many times or somethin.
  9. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Higher elevation = less ambient air pressure = less air compressed... so in short, lower at higher elevation.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The psi itself doesn't mean anything, as long you are within a few psi you are fine. Mine has 9.7:1 and at 6000 ft. read 160 psi all around.
  11. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Compression will vary due to cam duration but 160~180 is a good ballpark number. More important is how close the spread is, if this is your new motor it should be damm close or identical across all the cylinders.
    George
  12. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Thank you for correcting these guys, ambient pressure is directly related to your altitude and the weather( to put it crudely) 14.7 is the standard reading at sea level and at 59 degrees F' If you live at a higher elevation the pressure will be lower. any way to answer the question is for a 10:1 compression engine is approximatly 175 - 185 psi, assuming there are no problems. I only say this because I have tested a few hi-comp engines, not because I worked it out mathmatically :D
  13. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    cool.... thanks guys...
    As soon as i get my hands on a gauge (couple days) i plan to see if i got screwed off ebay. I REALLY doubt i did but i want to make sure...
    And yes this is my new motor.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    camshaft has a lot to do with it. not only the profile of the cam, but the cam timing as well (assuming you degreed it, probably not). no way to accurately say this is good, and this is bad. honestly, a compression test is pretty pointless anyways. you've got a brand new engine, why worry about it? if you want to know something about your engine, do a leakdown test.
  15. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I've had it opened up 3 times and am about to finish up cleaning out the heads and start it up.... i want to know if anything got into the cylinders and damaged any after i run it for a few seconds.
    I NEED to get the prominator and labtop but now i'm getting nothing from my dad(owes me over 2k) so I'm mobbin the honda for a couple months.
