what should i get?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by usafblzr, Sep 5, 2002.
  1. usafblzr
    usafblzr Newbie
    Aug 27, 2002
    arizona
    i don't know what combo to run, should i get a 4'' or a 6'' lift?and should i run 33'' or 35'' tires. i wanna mostly mud bog and rock climb. thanks for the info.
  2. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    35's will fit with a 4" lift, trim the fenders a little or put on some bigger bumpstops if the tires hit under full flex.
  3. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    depends how deep your pockets are /forums/images/icons/wink.gif
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    a 4" and 35"s looks nice and is a really common set up. that's why i went with a 4" and 36"s to be different. lol! but a 6" and 35"s looks good too. however a 6" usually means new drive shafts and steering stuff. of course even the 4" requires a steering arm, that's usually included in the kit. if i were you i'd go with a 6" and 35-37s. you get a 4" now and you'll want a 6" later, i did and i do.
  5. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    i've got a 6" with 35s and think it's great (and would hate to be 2" shorter!(no offense 4"ers))
  6. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    35's the smallest!!Where in Az. are you? and where is there MUD?I run 38's with 4" lift.35's with 4" lift gets my vote until you want bigger tires!Let's go wheeling!!Mike
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    hmmm...get what you want. Look at my pic thread to see how trucks look with different lifts and tires.
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i got a 4in suspension lift and 1 inch add a leaves all around, and im lovin every minute of it!
