What should I offer this guy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Sep 18, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It's a 14 bolt. The guy said he doesn't know if it's an '80's or '70's 14 bolt. He doesn't know what kinda shape it's in either. As far as that goes, I would treat it as one that needs a rebuild.
    Anyway, is there any difference between the '70's and '80's 14 bolts? How would I tell? How much should I offer him?
    What do I have to do to get it to line up under my blazer ('79-has a 12bolt right now)?
    If you see my truck on a trailer, call 911 cause it's <font color=red>STOLEN!!!</font color=red>
    Website link is in my profile [​IMG]
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i would say no more than a hundred bucks. who knows what it will cost you to get going.
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    The 70's are more likely the FF.
    The 80's are more likely the SF.
    Make sure you can tell the difference between the FF and SF.
    If he does not know the condition of it, no more than $100.
    Hope its a FF!!! [​IMG]
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    Wouldnt the SF be a 6 lug? or is that not always the case? Just curious cuz that might be one way to tell.
    Later
    Have you driven OVER a Ford lately?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    The 14SF is available in both 6 and 8 lugs.
    The 8 lugs are standard axles from '81 to '91 on 3/4 tons.
    The 6 lugs were started in '88 on the newer body style trucks.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    And to answer your other question - if it is a 3/4 ton it will/should bolt right in with the shock mounts in the correct position and everything. If it is a one ton version both the shock mounts and the spring perches will need to be relocated. You will need either a Napa 348 or 447 u-joint depending on your driveshaft. My '79 needed the #348, might be the same as your '79 is. Other than that, e-brake cables are the only other issue. Hopefully they drop right in like mine did from Wes the magic man [​IMG].
    Hopefully it is an open diff, then you pick up a Detroit for $300 and drop it in yourself (or with your significant other). And forget about clunking/breaking that pig......... Nevermore.............quoth the Raven [​IMG].
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    in an 85 stock, if it ff?
    ff means full floater right?
    whats that mean?
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  9. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    good god the ff has huge hubs on the ends. They have 8 bolts that hold in the axle shaft, and you have to take the shafts out to get the drums off. Another thing to look for are the bigger 13" drums. Later - Doug
    Doug Krebs
