What should I upgrade my engine and tranny to?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LoggieStyle, Nov 6, 2002.
  1. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    The transmission on my K5 just died and I figure now is a good time to upgrade the engine and transmission but I could use some help determining what I should put in.
    I'd like to put in a fuel injection engine and an overdrive tranny. I drive it a lot so I need decent gas mileage (anything around 10+ is fine) but I'd like to have a lot of power also. I'm not skilled enough to do the work myself so I'll need to take it to a mechanic, keeping that in mind my budget is up to $5000. Obviously the less it costs the better but I'll spend that much if I have to.
    So guys any suggestions?
    Thanks,
    Logan
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Go with a vortec 350 and 4l65E.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Well maybe that would be more than 5k.
    Well try and get a 350TPI and matching 4l60 or 700R4.
    That is only since you want to drive it a lot.
    If you want to take it off road and wheel the snot out of it then get a 454 TBI and a TH400.
  3. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    Thanks for the suggestion.
    I found a couple ads for newer 5.3 vortecs with 4l60e or 4l80e transmissions around $3500 in the local classifieds. But aren't those transmissions much more difficult to swap because they are computer controlled? That's what I was told anyway.
    Wheeling the snot out of it will come later after things stop breaking. Then I can go break them myself, so the TBI454 and TH400 might find it's way in there.
    Logan
  4. dremu
    Feb 27, 2000
    15,966
    457
    East of San Francisco
    Yeah, you'll need a control unit thingie to run any of the -E trannies (E for electronic). JET has these, aftermarket, I do believe.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well the reason I said they are over your budget because you said you will have someone install them for you.
    I think you will pay half of your budget on labor.
    Do some shopping in your area.
    That is why I do my own labor. /forums/images/graemlins/thumb.gif
  6. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    this is true. Damn. I wish I was competent enough to do it myself.
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Not meaning to hijack the thread but I think this is relevant...What is the difference between a T400 tranny and a TH400? I know the T400 doesnt have overdrive, does the TH400? I know the T400 is one of the strongest trannies out ther, is the TH400 as strong? Thx
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Afroman, they are the same trannies, just some people leave the H out of the name. TH400 stands for Turbo-Hydramatic 400.
  9. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You can get simple R&R's in Phoenix AZ for $400. Most of the engine rebuild shops will do it for $400. Thats for an exact replacement of course.
    I would do it myself though. Engine R&R is easy (just turning bolts,) its the getting it to run right thats the tricky part /forums/images/graemlins/grin.gif
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Build a 383 stroker with a TPI !!!! For a transmission, either a beefed up TH350, or a sm465. Think you'd be happy with that set up, I know I would.
  11. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    I think I am going to try to do the tranny work myself, no time like the present to learn right? I got quoted $2500 to put in a 700r4 from the local shop, I don't know if that is good or bad but it's more than I want to pay, I know I can get the transmission half or less than half of that. Besides, the less I spend on the transmission the more I can spend on the engine.
  12. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    $2500 is crazy. You can get a 700 rebuilt and the install for lees than a grand around here. I think most places will charge a couple hundred for the install. Doing an automatic tranny install is very easy.
