What size banjo bolt??
Discussion in 'The Garage' started by 85mudblazin, Aug 15, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am going to be buying the az-kickin disk brake hose kit for my 14bff and I dont know which size banjo bolt I need there is either 10mm or 7/16.
    -Chris
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Probably a 10mm. Depends on what year caliper you end up with. When you pick up your calipers ususally the auto parts store that you get them from will have those as well. Just test fit the banjo bolt right there. Check them both too. I have already had a mismatched pair.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I am going to be buying the caddy calipers with the e-brake that make a difference in which size banjo??
    -Chris
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    pm muddytazz I know he used the caddys on his swap with the Az kickin' kit.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thanks I just pm'd him.
    -Chris
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Chris, The Caddy calipers use the 7/16 banjo bolts.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Great thanks, muddytazz hasnt pm'd me back yet, good now I can go buy all my goodies!!!!!
    -Chris
