What Size Battery Am I Supposed To Have - K5 Blazer...
Discussion in 'The Garage' started by PWagon, Sep 2, 2011.
  1. PWagon
    PWagon 1/2 ton status Premium Member
    Mar 6, 2009
    384
    14
    Dallas
    When I bought my Blazer years ago, it was apparent the previous owner put a much smaller battery in the batt box. It's become obvious to me that it doesn't have the juice I need for all my accessories. I have already upgraded the alternator, but I want the battery to meet/exceed my power needs. Does anyone know what size these full size 12 volt Blazers are supposed to have (cold cranking amps, etc)?:dunno:
  2. sweetk30
    Nov 1, 2004
    24,892
    175
    horseheads , ny 14845
    i run mt-78dt interstates in my trucks.
    gets me 1000ca and also side and top posts. bolt in 100% no problems.
    i run side posts for truck basics. then all aftermarket stuff gets top post wing nut quick conect adaptors with reg nuts on them to hold wires tight .
  3. 4X4HIGH
    Dec 14, 2001
    22,012
    39
    Pleasanton, CA.
    The group size is a 24 so now just go ask the place you buy your batteries that you want the most CCA/CA battery in that group size (group size is the physical dimension of the battery).
  4. PWagon
    Mar 6, 2009
    384
    14
    Dallas
    Thank you guys... I appreciate your help on this.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    8,654
    167
    Grand Rapids area
    The answer is the same as for all vehicles - you need the biggest one that will fit. So this will likely be a bigger capacity than what came in it 25 years ago.
  6. dremu
    Feb 27, 2000
    15,783
    192
    East of San Francisco
    Physical form factor isn't an absolute indication of electrical capacity though -- in the group 78 you can get anything from prolly 500-600cca up to 1000 or so.
    Any *other* size won't fit in the snaps right, so you'd have to change the mounting around, or use a bungee cord or something =))
    -- A
