What size bolt for a rear shock????
Discussion in 'The Garage' started by BlueOx, Jul 30, 2004.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I’m about to order some rear shock mount tabs for the axle and they want to know what size bolt hole to drill in them. I told them I am going to use the stock bolt but, I didn’t know what size it was. They want to send them w/o holes since I don’t know want size bolt it is. I thought I wound ask if anyone knows what size the stock bolt is for my rear shocks.
    Anyone?
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    If I remember correctly I used 1/2" bolts /forums/images/graemlins/thinking.gif
    the Ford towers I had to drill out to 1/2" also.
    Not positive but I'm thinking 1/2" is right
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    1/2" is right. I know on mine I'm running 5/8" since i don't run sleeves in my bushings.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    However I forgot I drilled out the lowers..been so long
    After measureing my 14 bolt here at work under my burb and compairing them to tazzy's we came up with a 9/16" bolt.
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    why are you not running sleeves? /forums/images/graemlins/confused.gif /forums/images/graemlins/eek.gif
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    on my Wagon I'm not running sleeves so the shock can flex more and not bind. I was talking to Sky on this and he never uses the sleeves. all his tabs are punched out to 5/8"
