What size bushings for Furd 57's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, May 12, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    too tired to pull springs---does anyone know what size bushings go in the Furd 57's and where is a good place to get them?
    Dan
  2. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    anyone are they just 1.75 inside dia of the eye?--they looked a little bigger to me?????
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    You know I asked the same question a few months ago and didnt really get a response. When I talked to ord about they didnt have any greasable bushings available for them. I was standing there for about 20 minutes with a tape measure in one hand and the phone in the other hand. After searching some parts stores all I could find was rubber bushings for them. I ultimately went to 4 wheel parts, which carried some polys that came from energy suspension, sorry dont know the parts number or I would give it to you. Anyways, got the polys, cut some grooves in them, drilled a hole in the metal sleeve, and contacted ord about the bolts. A few weeks later I had my greasable bushings in the 57's. By the way all energy sells is a complete bushing set which comes with the shackle to frame bushing as well. And to add to this, I do believe that they might be a metric size bushing, I wasnt coming up with a number that seemed to make sense at anyone from ord that would be a standard size. Good luck, keep me posted.
  4. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Also the bolts sizes, if you want to know are 9/16 and 1/2. When I ordered the bolts from ord they had to get them from energy and it took a little while because its not an item that they normally stock. Which were the 9/16's bolts I believe.
  5. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Cool, i will give them a call--thanks for the heads up---i had a feeling it would be difficult.
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I used non greasable's from Energy on my Ford 57"ers. I went to the Energy website and looked up the truck I took the springs off of. I don't remember the P/N, but I remember there were two different styles, whether your original rubber ones were sleeved or not,I think. It was relatively straightforward when I looked for them on the Energy Suspension site.
