What size carb is most appropriate?
Discussion in 'The Garage' started by TRex, Jan 31, 2006.
  1. TRex
    TRex Registered Member
    Sep 13, 2005
    12
    georgia
    What size carb should i use on my 1986 chevy blazer with a new crate 350(stock),
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    600-650 cfm
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    I saw a formula to ball park this somewhere:
    (Cubic Inches) x 2 x 0.85 = CFM then round to nearest size (up if "healthy")
    so 350 x 2 x 0.85 = 595 so a 600 CFM carb
    if im remembering this wrong someone please correct me!
  4. TRex
    Sep 13, 2005
    12
    georgia
    some guy told me that for a stock 350, a 500 cfm two barrel was best. Is this true?
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    TRex, what part of Georgia are you in? Stock quardrajets were 750cfm. A popular choice with edelbrocks seem to be the 600cfm. I would think that a two barrel 500 cfm would not be very good for power.
    Thanks,
    james
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    That .85 is for volumetric efficiency. A fairly built motor would be at more like .9, stock is probably .8. If you are going with a Q-jet, its 750 CFM will not be too much. If Edelbrock/Holley go with 600.
  7. TRex
    Sep 13, 2005
    12
    georgia
    I'm from Kennesaw, but I actually go to school in Kentucky. What about you? and what about a 600 Holley?
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm not too far from Columbus or Thomaston. Yeah a 600 holley will be fine, you whould look into the truck avenger series which is a great holley for offroad. The only downside I've ever heard about holley is that the old ones used to have power valves blow out if you ever had a backfire through the carb, but I've never dealt with a holley in real life.
    Summit has Edelbrock off-road thunder 650 cfm carbs for $350
    Summit has Holley Truck Avenger 670 cfm carbs for $410.. they also have a 470 cfm carb for the same price.
    Alot of people really like the stock Quadrajet Carbs, they are supposed to be the "poor man's fuel injection". Carb tuning is kinda confusing to me, so I got a little aggrivated with a q jet recently and am going to swap in my old edelbrock 600 cfm (soon to be converted to an off road carb with a cheap kit).
    Just do a little research. You won't be dissapointed with either one of the first carbs I listed from summit. You could always try to install TBI, so you won't have to fool with carb tuning. You just need to find a donor truck and get all the fuel injetction goodies off of it. Search around, there is more stuff than you could ever want to know on this website.
    Thanks,
    James
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    you can buy the truck avenger on ebay for a lot less than summit or jegs, I bought a new 770 cfm for 329.00
  10. TRex
    Sep 13, 2005
    12
    georgia
    Do you think that the Holley Truck Avenger 670 would be too much on my stock 350? would it flood it?
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I would imagine that this would be just perfect... I'm not sure if a 470 would be too small or not, just gotta seach around.. If it were me I think I would go with the 670.
    thanks,
    James
  12. dave_90_blazer
    Jan 1, 2004
    688
    should be fine, espectially if you have headers/aftermarket intake, ect.
  13. TRex
    Sep 13, 2005
    12
    georgia
    Iv'e got headers and im gonna get an in take, right now it's stock, but I'm thinkin of getting the edelbrock performer.
  14. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i say stock q-jet. My holley floods out easier and uses more gas then a stock q-jet and has no power up steep hill climbs plus harder to start on the side of a hill. The q-jet is a poor mans fuel injection for keeping the engine running. Id grab an older style (no smog ****) rebuild it and run it. Plus all the stock stuff bolts to the q-jet. I like running stock closed box air cleaners when wheeling and an open air cleaner when driving around and the q jet makes it easy to swap cleaners.
  15. TRex
    Sep 13, 2005
    12
    georgia
    what kinda holley?
  16. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    holley model 4150 i think. 30cc Double pumper, dual metering plates, 750 rated cfm, spring loaded needle and seats low fuel bowls dual fuel filters and pumps (helper and mech). Hate it off road, love it on the street.
  17. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I have a 383 with headers and will run a TA 670...
  18. TRex
    Sep 13, 2005
    12
    georgia
    do you think that a TA 670 would be alright on my stock 350 with and intake and headers?
  19. TRex
    Sep 13, 2005
    12
    georgia
    what size would a stock quadrajet be if it came on a 305?
  20. TRex
    Sep 13, 2005
    12
    georgia
    Were you using a Truck Avenger?
