What size fuel cell
Discussion in '1982-Present GM Diesel' started by DEMON44, Nov 9, 2005.
  1. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    What size fuel cells are the big 3 using in their current fleets of diesel pickups?
  2. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    So NO ONE here drives a diesel truck newer than 2000?
    Just asking how much fuel you put in from empty :doah:
  3. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    1999 and up ford super dutys either a 29 or 38 gallon tank depending on wheel base.
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Maybe someone can enlighten me if I'm wrong, but it seems GM pick-ups are notoriously short ranged. The older pick-ups came with what, 21 gal tank. I just used a work truck 2001 C3500HD utility body with a 6.5 turbo. After the long trip I went to fill it 'cause it was down to a quarter tank, and the truck STALLED on the way to the pump! :eek1: I made it to the gas station (barely) and it only took 18 GALLONS OF FUEL, WTF? What was GM thinking, this thing probably doesn't get 10mpg on the highway. :mad:
    Back to the thread at hand.
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My crewcab long bed 98 with a 454 has a 35 gallon tank so I assume all engine options would. I'm willing to bet tank size is based solely on chassis length. Out 97 extended bad short bed only has a 27 gallon tank but again, these are both gassers.
  6. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    thanks folks.
  7. skark_burmer
    skark_burmer 1/2 ton status
    Oct 31, 2005
    123
    San Jose, Ca
    My 05 2500 HD shortbed with a duramax has a 28 gallon tank.
