What size fuse should I use for my amp
Discussion in 'Audio' started by kwcdawgfan, Mar 3, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    the amp is 160 watt amp??? Thanks for any help
  2. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    Look at what size fuse is installed in the amp, I would say around 15-20 should be suffecient.
    If it aint a Chevy don't raise it up!
  3. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    20 should be good for that size amp.
    [​IMG] '87 Beast
    Colorado, USA
  4. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    I know this may sound like a smart a$$, but read the manual. It will tell you what to use. If you go to big, it will drag and if you go to small it will blow out. Trust me been there.
    <A target="_blank" HREF=http://www.rockosangel.coloradok5.com>http://www.rockosangel.coloradok5.com</A>updated finally!
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If your manual doesn't say what amperage fuse to install, try this:
    Watts divided by volts equals amps. 160W / 12V = 13.3A
    Try a 15-amp fuse first. If that blows regularly, step to a 20-amp, but no higher. I'd use no less than 12-gauge primary wire to run your power to the amp, to ensure that the fuse goes pop, and not the wire.
    [​IMG] Semper Maintenance!
  6. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    JarHead,
    The only thing I'd add is that the voltage in a properly setup car audio system should be 14.4v with the engine running....so modify your fuse calculation accordingly.
    With the engine off, it is unlikely that even a NEW battery will show exactly 12v... Just a thought.
    -Greg72
    72 CST Blazer
    No stereo....but I'm already making plans! [​IMG]
  7. kwcdawgfan
    Jan 13, 2001
    91
    Georgia
    I put in a 15amp and havent had any problems so far... Guess I must have gotten a good ground because I have absolutly no engine noise... Appreciate all of you helping out
  8. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Greg72, you're right. Had a bit of brainfade there... But I did remember Ohm's Law correctly, so I gotta pat myself on the back for that!![​IMG]
