What size gap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Sep 7, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I need to change my spark plugs and wires tomorrow. What size gap should I make the plugs? the ignition is stock.. not big mods on the truck (yet). I figure .45 or less?
    <a target="_blank" href=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</a>
    ".. Sanatarium.. leave me be..."
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    When you buy the plugs ask them there. It varies between different plugs and engines.
    Brian
    83 K-5 4" on 33's
  3. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    .35 -&gt; 87 350
    Surfing is Life...
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    When a bought a set of Champions I think the gap was .035" but, yes it does vary on the manufacturer.
    74 Blazer
    Zepplin
    Check out my Blazer <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  5. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    both my Chilton and Haynes manual say .060
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I set my Bosh Plat. to .45 for my 350
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Man that seems off unless you have like a MSD in there or something... I gap mine at .35 to .40... it seems that gap at .60 is too wide and will be too hot to work right correct?
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  8. dyeager535
    26,982
    191
    When GM first started using HEI they went way overboard on gap, then dropped it way back down the year afterwards or so. Olds ran .060 up until the very end, and since its the same HEI system, unless the electrode hits, you *could* run that gap on a Chev too. (but run what the factory recommends)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
