What size gauges can I replace my stock ones with?
Discussion in 'The Garage' started by dallassnowman, Jul 22, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Looking at autometer, but don't know what sizes to get 2 are large and 4 are small....
    Does someone know who has done this??? :confused:
  2. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    do a search there are a few people that have done it.
  3. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    I'm in the process of replacing my stock gauges with almost all new autometer procomp gauges. in the small ones, the smallest autometer has is 2 5/8 i think. these will prob need some work to fit if you plan on somehow mounting them behind the dash. But, I noticed that they looked fairly close to the size of the small holes where the chrome ridge around the hole was. But, they had this plastic cone behind it that closed in on the face of the smaller stock gauges. I used wire cutters to cut the cones out...It took a long time and some patience....maybe if you have a better tool it might get done quicker. didn't want to wreck or crack the dash though...Finally, I got all the small ones cut out, and the new gauges slide right in the holes and the ridge around the face of the gauge covers the chrome ridge of the hole anyways. They come with something so you can secure the gauge to the back of the dash. I'm still working on figuring out just how to secure the speedometer since it is the same size as the original and i cant do that mod there. The old fuel gauge hole I might just block off for now, autometer only had a smaller fuel gauge, the old one was broken and i dont really need a tach. i'll try to post up some pics when its done..it might be a few weeks till its all done though.
  4. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    ok, that helps....yeah like to see pics!!!
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    2 5/8" gauges...mounting them was a piece of cake. The second pic shows the 'cone' you need to remove.
    The larger holes can be filled the same way with 5" gauges.
    Hope you got some money set aside, the speedo is well over $200 and the tach is near the same. It adds up quickly!
    Rene
  6. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    hey, i'm assuming from your post you went with the 5" speedo?... maybe i should have done the same, i got the same size as the original :doah: . now i'm trying to figure our how to mount it...won't match up with the stock screw holes, and without it sliding in like the others, it wont be able to clamp down like them.... :crazy:
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    No, i haven't gone with either a speedo or a tach yet. Mostly because it just isn't in the budget right now, but also because they don't make a diesel tach in the Ultra Light series. I am not going to run a 10,000 rpm monster tach for a 6.2...:D
    The very outer ring on the bezel is 4 7/8", so making the hole 5" so the 5" speedo and Tach fit would be pretty easy.
    Rene
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Although they are a little small , Autometer 2 1/16 gauges ( or any manufacturer ) fit the factory gauge holes without cutting . They sit pretty good in the dash bezel , and the clamps on the back just need a hand bend .
    I used cheapy parts store ones myself . So I can spend money on other stuff . I am not above cutting anything for bigger ones , just doing a budget build .
    I am not using the amp gauge though now . Decided on doing a volt gauge , so I have to buy a single gauge now , and use the amp gauge for a paperweight .
    [​IMG][​IMG]
  9. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Rene[/QUOTE]
    :confused:
    WHAT BRAND AND MODEL ARE YOUR GAUGES???
    YOU'RE SETUP IS NICE, THATS WHAT I WANT TO DO!!!!
  10. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    They are Equus guages..
    If you look in the thread that tRusty posted about them and scroll down, I put up a link where you can get them.. :thumb:
    Here is the link to the thread http://coloradok5.com/forums/showthread.php?t=144041
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Thanks Mudslinger. So far I'm pretty impressed with the Equus stuff, but they do have a pretty limited selection of gauges. It's a good thing they're a close match to the Autometer Ultra light series, so as I add gauges later the Autometers won't look out of place.
    Rene
  12. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    How do you hook up the water temp gauge??
    its mechanical right....
    wasnt the old one electrical??? :confused:
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    It comes with a few fittings and a sensor screws into the block where the electrical sender was. The line to the gauge is filled with some gas and cannot be cut/shortened or otherwise molested. :wink1:
    Pretty basic, just have to drain some coolant and screw it in.
    Rene
  14. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    how are you liking the mechanical Rene?
    i really liked the accuracy of the one i used to run... more annoying than electrical to route i suppose..... but also not as susceptable to the "wire on a header syndrome".. i went electrical this time out...
  15. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Where is the electrical sender located on the engine.
    I've looked in the 3 books that I have and can't find it!!
  16. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,618
    608
    Hooper, Utah 84315
    What kind of engine. Most times for water in the head left or right inbetween exhaust ports 1 and 3 or 6 and 8 or in intake near upper radiator hose at least thats where they are in SBC.
  17. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Diesel 6.2
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Look for a single green wire on the drivers side head towards the front.
    Rene
  19. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Thanks.....I'll say it again the membership fee is well worth it...
    CK5 is like an online school, I just keep learning!! :D :deal: :weld: :grind: :hack:
  20. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    exactly why I'm not gonna run either one. I never had a tach in my rig, and my speedo hasn't worked in over 3 years... no ill effects as of yet. Why waste the $$$?? :)
    j
