What size is it?......
Discussion in 'Pacific Region' started by blazer88k5, Sep 5, 2002.
  1. blazer88k5
    blazer88k5 1/2 ton status
    Aug 23, 2002
    103
    Modesto, Ca
    OK I just picked up another K5 an '82. It has a lift with blocks in the rear. How do I tell if it is a 4" or 6". Can I measure the block in the rear?? Or is there another way? My 88 is still stock height so I can't compare it to something? Since it was a lien sale I cant ask the previous owner.
  2. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    measure the block in the rear and that will give you a good idea. Most people that only do a small lift like 4 or 6 don't use a combo of springs and blocks they just use blocks for the lift.
    David
  3. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    Measure from the center of you wheel to some point on the truck and compare it to the same measurements on the stock truck.
