What size is the drain plug np208
Discussion in 'The Garage' started by blazer_87, May 22, 2004.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    Can someone tell me what size socket fits the drain and fill plugs on a NP208 Transfer Case in my 87 K5? Thanks
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Don't know the size since I've always used a large Crescent wrench with no problems.
    Kain likes this.
  3. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    I *stink* the '208's are the same as the '241... anybody? Bueller?
    On my '241 I couldn't get an adjustable on it was the head is so low-profile and the corners are rounded /forums/images/graemlins/frown.gif
    I am told that a 1 3/16" socket will fit it, but I seem to recall that 30mm is the actual size -- considering they're within .006" of each other I think either would do /forums/images/graemlins/laugh.gif
    -- A
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    As far as I know, they are different. Tried a Crescent on a 241 and wouldn't work, but on my 208 I regularly use one.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    it is a 30mm I jsut went and looked in the garage at the socket. Only reason I have that blasted size lol.
  6. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    its 1 3/16ths
    Nick
  7. 88chevyk5silverado
    88chevyk5silverado Registered Member
    Apr 17, 2010
    29
    Renton Washington
    Are u sure its not 1 13/16th?
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Holy crap, this thread is 6 years old. The proper size socket though is a 30mm and the 208 and 241 are the same size.
  9. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    The fill plug also has a very "thin" hex,so it might be best to use a 6 point socket the first time!..one on my NP208 was REAL tight and someone boogered it up,probably used an air impact on it...there is a lip on the case that might not let a thick walled socket go on it good though,so you may want to use a thinner socket rather than a thick one like an impact socket..I had to use a 1-1/8" socket on my fill plug,but it probably was 1-3/16 to start off!..
  10. Coldpunk
    Coldpunk Registered Member
    Oct 7, 2010
    77
    Columbia, Missouri
    Np241 socket size
    After being misinformed by another thread I can assure you 1 3/16 is not the size. I'll be returning that and picking up a 30mm on the way home tonight.
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Haha Im still right 7 years later
  12. greggkay
    greggkay Newbie
    Mar 13, 2012
    5
    Parker, CO
    I know this thread is old, but maybe someone can help. Yes the fill plug on a 208 and 241 are hte same size - 30mm. However, that is rounded off and still stuck tight. It looks like there is an 8 point torx bit (double square?) hole in the center of the fill cap that is very large. Does anyone know what size bit will fit that and where i can get one? Also, would applying heat help get it off?
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Tap on the plug first before trying to remove it.
  14. sreidmx
    sreidmx Fortify Offroad Vendor
    Oct 24, 2013
    4,869
    2,789
    Morongo Valley Ca
    I had to use an impact to get mine off!! dont over tighten it!
  15. dyeager535
    26,980
    Ignoring any possible issues the heat may cause to other components, I'm a convert to welding something to stuck fasteners that allows me to get that fastener off instead of trying to work around it, or drill out, or use an ez-out, etc., IF the item is truly stuck. Nut welded to the head of a bolt mainly. Heck, I've welded pipe as a handle onto a bolt that I wasn't afraid of breaking.
    Probably wouldn't want to break the case, but leverage is a fascinating discovery. :)
    sreidmx likes this.
  16. sreidmx
    Oct 24, 2013
    4,869
    2,789
    Morongo Valley Ca
    Its pound for feet better than inches.. :hack:
