What Size K&N?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86K5inMN, Aug 16, 2000.
  1. 86K5inMN
    86K5inMN Registered Member
    Aug 7, 2000
    28
    Minnesota
    I want to order an open element, 4-6" K&N Air Cleaner. I'm not sure what size or specs I need. Jeg's has 4 different styles depending on individual needs. I am fairly car saavy but I'm not sure which will fit. I know I probably need a drop base and most likely one that is offset for HEI. Just hoping someone out there had already figured this out. Thanks for the help!! Hope I can contribute more once I learn more about my K5!!
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'm running the stock replacement K&N and the stock air cleaner. All I did was turn the air cleaner cover upside down to make it breathe better. Works great. Noticed a definate improvement. Specially when towing, over the paper kind. Also have headders, TBI spacer,flowmaster,fast chip & MSD, The K&N toped everything off.
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Should be able to run an 14inch. Should be able to run 6inch filter with drop down base.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I checked with K&N on this and told them I had a 350 w/750cfm Edle. Q-Jet and wanted to run a 14" round. I asked them what size to run 3", 4",5", 6". They said that anything abouve 4" really wouldn't do much more for the airflow. They said the carb wouldn't beable to take in any more air than what the 4" can provide so that is what I got.
    Now the 5" or 6" if you have the room and you like that super high looking air filter still can be used, but at that point it's all for looks and not function!!
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
