what size lift do I have?
Discussion in 'The Garage' started by lason, Jun 8, 2004.
  1. lason
    lason 1/2 ton status
    May 31, 2004
    105
    Arlington TX
    OK so now some guys on another board (also members her I believe) got me thinking that I may be wrong in saying that my rig has a 8" lift. That is what the previous owner said it had and I just went by it. Anyway I measured from the body line to the hub and got right at 34" front and back. Could someone else with a stock body and 8" or even a 6" lift measure theirs and see what they get? BTW, here is a pic of it sitting on the worn out 38.5" TSL's.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd say you are more like 6" of lift. I just went and measured mine for you, from body line to center of the hub is about 32 3/4". Thats 4" BDS springs, and a Dana 60 so about 5" of lift.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I say they may be 8" springs in the front but you are sagging horribly in the rear.
  4. lason
    May 31, 2004
    105
    Arlington TX
    Its not sagging. That is why I got a measurment of 34" front AND back. The truck is on my sloped driveway so it just seems that way. Im going to try to take a pic of it in the street to see if it looks a little more level.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I couldn't get the rear measurement for ya, don't have a rear axle under it right now.
  6. lason
    May 31, 2004
    105
    Arlington TX
    I appreciate you taking that measurment though. Im thinking 6" myseld but o'well it really doesnt matter I suppose as I plan on switching over to a set of 6" Tuff Country Springs front and rear and ditch the rear blocks. BTW, kinda off topic, but while looking at springs I see they offer a 52" and a 56" rear spring. If I switch to the 56" I will have to move the rear spring perch back right? Also will I get better flex with the 56" as compared to the 52"? I say this because I was planning on doing a 56" out back and a 52" up front and thus increasing my wheelbase for better approach and departure angle and also increasing my flex. Does this sound about right?
  7. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    looks like 6" to me
  8. mrk5
    Apr 20, 2004
    12,338
    1,045
    Northern Colorado
    I just read an article in Petersen's 4wheel and offroad or Four Wheeler about this very thing, and on a blazer no less. They put the longer springs on the front. It was an interesting article.
  9. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    If it has blocks then just measure the blocks, then you'll know if its 6 or 8
  10. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Did you measure from the body line that is right above the door lock and runs the lenght of the blazer?
    If so, here's what I got:
    38 1/2 rear, 38 front - 9" lift using 6" springs up front and a 4" block and add-a-leaf in the rear and 3" body lift.
    Does it have factory rear springs? If so it is probably only a 6" lift, like someone mentioned earlier you could measure the block.
  11. lason
    May 31, 2004
    105
    Arlington TX
    Yup, thanks for the info guys! Im now believing it is really a 6" lift. Now what about the spring question above?
