What size lift springs are these?
Discussion in 'The Garage' started by mountainexplorer, Mar 7, 2002.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have 3 pairs of front leaf springs. The one pair I know for sure are 6" lift. A second pair was also supposed to be 6", but they sit an inch taller without weight on them. I figure they'd sag the extra inch. Then the third pair sits 2 inches taller than the first (again without weight). Pictures are at http://community.webshots.com/user/aalundberg under the parts and misc. stuff album. Can anyone tell if the tallest ones are 8" lift springs?
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    If you know that one pair are 6" springs, I'd measure from the center of the spring to the floor (place them the same way you have in the pic) and compare that measurement to the measurements you get from the others.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The only way to know is to calculate the spring rate (I don't know the formula off hand but Greg72 might be able to help you out w/ his excell file?) and to devide the weigh of the front of the truck w/ it. ie. (weight of truck)/(spring rate). You could guess on the weight of the truck and figure out the lift compaired to the known 6" set.
