What size lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Dec 14, 2001.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    If I put 33's on my blaze what size lift should I put I don't want a body and a 4inch would look funny with those 33's and a 4 inch or I could put 35's ,but afraid it woulden't take the abuse.
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Why wouldnt it take what abuse? 33's and 4" don't look bad, go for that or 35's with a tad bit of triming if you flex if you just do mud and street then you can do 35 and 4"
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  3. blazingboy
    Dec 2, 2001
    120
    Georgia
    Well I am 16 its got 10 bolts front and back with 3.73s and a overdrive tranny
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Well, I have 10-bolts front and rear, with 4.56 gears, and full detroits in both axles, as well as 35 BFG MTs with 4" suspension and 1" body lift. My rig takes the abuse quite well. Spent quite a bit of time pulling vehicles stuck in the mud up to their frame this past weekend. So, it will stand up.
    However, if you only want 33s, I would suggest a 4" lift. It is the only way to go and guarantee no rubbing under flex. Plus, you will have room to go taller later, which you will.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I am 16, 4.56, 35's soon to be 36's or 38's, soon to have eaton posi with 10bolts... taking ALOT of abuse... but never failed on me.
    305/Sm465/ NP208
    Kn, 4.56's.
