What size of engine is it?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Klef72K5, Feb 12, 2002.
  1. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    I inherited a block that I believe is a Chevy. It has no side motor mounts, 2 bolt mains and the oil filter has a adapter that bolts onto the side of the block. Is this a '57 283 or 265? Maybe something else? The only casting numbers I found were 86133. Do any of you know? Thanks!
    <a target="_blank" href=http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg>http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg</a>
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    replaceable element oil filter like that was used from 56 to 69 on 265 283 307 327
    what is the letter code on the stamping pad at front pass die of engine aboeve timing cover ?
    run it til it breaks, fix it, and break it again!
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    <a target="_blank" href=http://www.mortec.com>http://www.mortec.com</a>
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    How many head bolt holes around each cylinder?
  5. Klef72K5
    Apr 8, 2001
    249
    Know I'm thinking it's not a chevy. It has 4 bolts around the cylinders. With only 10 bolts per side! On all the cylinders it has a very deep champfer that goes around 1/8 of the cylinder. Seems to me it would cause the head gasket to blow.On the intake it looks like it gets a pan gasket. The reason I say this is because it has 2 screw holes down the center of the valley and on the ends it is very rounded. It is also VERY open down the center of the valley and around the lifters. The dipstick goes in on passenger side and it looks like it slants forward alot by the angle of entry. I did find where there are motor mount bosses. There is only 2 per side and they parallel to the oil pan and very low. The motor is blue.Not for sure if it's original. The distributor sits in the rear. I also could not match the numbers on the website posted above. I had already looked there.
  6. Steve_Chin
    Mar 6, 2001
    1,126
    I thought so. It sounds like a Pontiac. Are there any numbers cast in the lifter galley area? There's a date code by the distributor hole (4 digits; one letter, three numbers), there's also a two letter engine code stamped on the front of the block on the passenger side of the engine, just near where the cylinder head meets the block.
  7. Klef72K5
    Apr 8, 2001
    249
    In the lifter galley area there is no numbers. It is very open in there by the distributer the stamp reads 86133. On the front of the block on the passenger side of the engine there is a 4 digit number.
  8. Steve_Chin
    Mar 6, 2001
    1,126
    Hmmm... Those don't sound like Pontiac numbers... Mayber a SB MoPar? I still can't access the link you've provided.
  9. Klef72K5
    Apr 8, 2001
    249
