What Size Pipe For My Roll Cage
Discussion in 'The Garage' started by 4wheelin4Jesus, May 19, 2005.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    I am going to be fabricting a roll cage for my 78 jimmy. I wanted to know what you all recomend for the size and thickness of pipe that i should use.
    any pics of roll cages would be cool to.
    thanks and God Bless.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    none....
    you don't use pipe for roll cages, you use tubing. 1.75 with a .120 wall is pretty standard strong tube. DOM is much preferred.
  3. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    i thought that tubing was square, and pipe was round?
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Nope, tubing can be round or square. DOM is preferred, but depending on the type of wheeling you do, that should drive your decision on what material to use. Competition regulations stipulate DOM. If your not really into hardcore stuff, consider HREW. It's a lot cheaper but plenty strong for the occasional outing. If you're not into real hard core off camber stuff, it can be considered. If you plan on running w/out the top a lot and need something for the family, please use DOM. Cheap insurance in case of a bad accident.
  5. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    thank you for your reply. im a welder from years back. welded i-beams on large buildings. this thin stuff is pretty forein to me. what exactly is dom? I am taking it from the guy who replied earlier that it is around 1 1/2" in diameter, and pretty thin.
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    DOM means "drawn over mandrel". It doesn't have the visible weld seam.
    The size Sled_Dog referred to is 1.75" OD with a wall thickness of .120 or 11ga. ID is 1.510.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    DOM is just a name for a type of tubing. It means Drawn Over Mandrel. HREW is Hot Rolled Electric Welded. If you see the two side by side, HREW has a seam down it. This can be a failure point under extreme stress(roll over). I would agree that if you don't forsee ever being on your lid(just doing it as a precaution) HREW could be good enough. For many of the guys around here who have been on their lids a few times, DOM is a must.
    I recommended 1 3/4" with a .120" wall(1/8").
  8. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    thank you all for all your help.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    Hey Mandic, DOM has a seam just like HREW...in fact up until it's been drawn over that mandrel DOM is identical to HREW. The big reason for DOM is that manufacturing tolerances are tighter so the wall thickness variance is a lot less with DOM than with HREW. We are talking about 'thou's though.
    About the only seamless stuff I've run across is CDSM (Cold drawn seamless mechanical tubing) Spendy as hell though.
    I wouldn't call DOM 'cheap insurance' either. Around here it'll run you double what HREW costs.
    If i had an ID pipe die for my bender I wouldn't hesitate to use pipe for bumpers. You do have to be specific when ordering material though. Black pipe is not what you want...that is total plumbing only kinda stuff. 1010 mild pipe is just dimensioned by it's ID rather than it's OD. Aside from that difference it's basically HREW too.
    Rene
  10. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You can build it out of pipe and make it work just fine if you want... You will just have to use thicker material (more weight) to get the same strength as you would get w/ lighter tubing.
    My cage is 1.75 .095 wall tubing, I have roll tested it, and it holds up just fine!!!!
  11. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I know Sally Biffle, Greg Biffles mom, and she says the .095 wall 1.75 is what they use on the race car. She also owns J&S steel here in Vancouver ,so she probably knows what shes talking about.
  12. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    thank you for your reply. taking out the obvious choice of cold roll being the best, what would you recomend that I use?
    thanks
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Sounds like Rene know his stuff on this one. You need to decide suits you personally. After hearing what Rene has to say on the subject, I'd seriously look at the cost difference between HREW and DOM. I know I can get 1.75x.125 wall DOM for $3 per ft. I my price on HREW is some where in the $1.90 per ft. range. Big difference there.
  14. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    I like 1.75 ,if its good enough for nasscar ,its good enough for your car :D I think the 3" looks good but it take up alot of cab space. so what I'm doing is 1.75 and then wrap it in padding
  15. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I made the mistake of buying 2" DOM for the main hoops for my dodge. Nobody has 2" dies, they stop at 1.75. Even the chassis shops, 4x4 shops and even most hydrallic shops.
  16. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    Hi five !! As I have said before ,my dad is a welder/millright and made lumber racks of customers for 35 years out of regular pipe !! Regular pipe is like a timex; is very strong and maulable[ie,rolling your blazer over].If I wanted to go to a stronger tubing ;I would use cro-molly or stainless .
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    good to see another vancouver-ite on ck5. :) what part of the 'couve are you in? Ive been to J&S steel before... got some square tube there once...
    *end hijack* :grin:
    j
  18. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    hey Jekbrown I'm at 39th & main , where are you at?
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Didn't know that, good to know. I'm used to the big old seam of HREW, guess I never noticed the seam on my DOM. I didn't say it was cheap :p:
  20. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    The seam on DOM is less visible, but is is definitely there.
    IMO, the strength gained versus the extra cost is not worth it to me, for what I do with my truck. Good design with lots of triangulation is likely going to be much more important. I can understand going the extra mile in a competition rig, or a race car though. The tighter tolerances of DOM ensure thinning of the walls in the bends is minimized as much as possible.
    Diesel Dan: JD2 makes 2" tube die sets. The 2" set is the largest you can get for the model 3 bender.
    To the original poster; sorry for the hi-jack. Most guys here use 1.75" tubing. Most common is .120" wall although some feel comfortable with thinner tube.
    Rene
