What size pipe???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka73, Apr 21, 2000.
  1. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    What size pipe should I go with for my duals to run my headers through, I went to a local muffler shop and I asked for the 21/2" pipe and the guy said "why do you want 21/2s" I say well for more air flow and more power the damn guy laughed at me he said that 21/4" is the same as 21/2s is this true, would I get the same torque and power with both sizes the price is the same for either one what would you guys recommend thanks by the way I'm going with Flowmaster 40s
    keep blazin !!!
  2. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    What size is your header outlet?
  3. chaka73
    377
    Southern California
    I have 21/2" outlet headers.
    keep blazin !!!
  4. Grey Thunder
    Grey Thunder Registered Member
    Mar 2, 2000
    65
    Home: Ojai, Ca......School:Santa Cruz, Ca
    THEN YOU SHOULD GET 2 1/2 PIPES...
    " If it ain't a chevy, don't raise it up"
  5. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    The customer is always right......go somewhere else to get your 2 1/2" pipe.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  6. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Large diameter pipes primarily help wit high RPM horsepower. Fow low end torque, it's actually preferable to go with a slightly smaller pipe size. I have a 2-1/4" dual kit from Dynomax and have planty of power for my needs. It basicly comes down to personal preference and cost. I think that you'll probably be happy with any size dual exhaust over 2".
  7. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    Let me know what you think of those flowmaster 40's. I'm considering them for my next purchase.
    10 BOLTS O' FUN
  8. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I think 2.25 pipe would be plenty for your truck unless you have a 500 horse mud bogger. Blazers are usually slow and heavy and could use the torque more. I have 2.25 inch pipes on mine with the Flowmaster 40's...I love it. Some people might say its too loud, but its good for me.
    '73 K5
    Chevy good...Ford bad
  9. SVBlazer
    SVBlazer 1/2 ton status
    126
    Boxford, MA
    I've got the 2.5" duals with Flowmasters. You will have a couple of places that the exhaust will restrict depending on how you plan to install system. Most shops do not have mandrel bent tubes, so you end up with restrictions at the bends. So you might consider these restricted areas when designing your system....just a thought..
  10. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    My exhaust was done with 2" pipe. I had some flex pipe with cherry bombs and now I have full exhaust exiting behind tires with turbo mufflers. It actually runs better now with more backpressure. Unless you have a extremely built motor you don't need a big exhaust.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  11. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I agree with most; you will get better torque out of smaller pipe, but you will get a deeper more mellow sound with larger pipes.
  12. NJ SAR Guy
    NJ SAR Guy Registered Member
    55
    New Jersey, soon Florida
    Thank you, Snoop Dogg!
    NJ SAR Guy
    Please excuse all of my misspelled wurds.
  13. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    first off, that title kinda got me. i thought this was a pot thread!
    anyway...
    the reason the guy said that the two sizes are the same is probably due to the fact that different industries measure things differently. you were talking outer diameter, he was talking inner diameter.
    or he was just a dick.
    <font color=purple>delta9blazer</font color=purple>
  14. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    This thread helps me out quite a bit. So far I think I'll probably go with 2 1/2" pipe and Flowmaster. Hmmmm......Blazers being big and slow?!?! YEP!! HAHAHA When up to speed they are sometimes difficult to stop too!!
    "Crutch" Huckins
    What me get stuck? NEVER!!(Famous last words)
