What size shims
Discussion in 'The Garage' started by readymix, Nov 18, 2004.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Here is the problem.
    I took out my D-60 to replace the bushings with the HD ORD Greasable ones. I figured i would rebuild the springpack while i was at it to get rid of all the rust. After i cut off the head of the centering bolt and removed the shim it fell apart. "Crappy Cast Aluminium"
    Since the axle is out and the spring packs are apart, i can not measure what the shim angle should be.
    Does anyone know what it should be.
    1987 Chevy Longbed, Dana 60 Front with 6" Skyjacker (I think) not sure of the brand. Axle has not been relocated forward or back.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Measure the height of the shim at each end and also the length of one of the sides, preferably the long side that makes a 90* angle with the short side. Or all four sides if you can't figure out which side I'm asking for. /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just bolt it together without the shims.
  4. readymix
    May 30, 2004
    6,706
    26
    I think i have measured it out to 4 deg. At this point i think i will go without them as you suggested Tim. Will i notice any downfalls to not using them.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Probably not if you run an automatic trans, your driveshaft is quite a bit longer than mine.
  6. readymix
    May 30, 2004
    6,706
    26
    SM 465 and a 208
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    SM 465 and a 208
    Still a longer combo, I'd run it and see how it works out.
  8. readymix
    May 30, 2004
    6,706
    26
    OK, will do.
    Thanks for the input
